VF-34 questions
Old Nov 24, 2004 | 06:44 PM
HKSwrx02's Avatar
Car Info: 2002 WRB WRX
WRX RUSH Thanks for the input
What kind of engine management options do Vishnu and I-Speed offer for this set-up? or is there anything better than what those two offer.
Old Nov 24, 2004 | 07:33 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Reflash which you have 2 maps (usually full and half boost/valet maps) but the second map can be set to a race gas or a different state gas.
Vishnu also uses XEDE technology which allows you to store 6 or 7 different maps, there really is no call for it, but some guys do use it.
Rush
Old Nov 24, 2004 | 07:43 PM
HKSwrx02's Avatar
WRX Rush thanks for the info
Ill look into Vishnu's ECU options and hopefully decide on which route to choose.
Old Nov 25, 2004 | 09:16 PM
mmboost's Avatar
Originally Posted by mmboost
1. Any uppipe that fits with the stock turbo will work with any of the VF series turbos.
2. You do not have to replace the intercooler. With the stock intercooler + vf34 you can safely peak at about 17.5 to 18 psi. If you do want a more effective intercooler, go straight for the FMIC. A larger TMIC isn't worth the high cost.
jason
I learned recently, from a real pig, that the vf39's don't mate up with the WRX uppipe... only the STi flange. Ooops, FYI.
Old Nov 25, 2004 | 09:30 PM
HKSwrx02's Avatar
So dose this mean i should switch Up-pipes or will my HKS pipe work with the VF-34?
Old Nov 26, 2004 | 10:18 AM
MO REX's Avatar
Car Info: 02 PSM WRX
You could save an extra $25 buying from MJP http://www.mpjperformance.com/main.html.
Your upipe will work with the VF34.
GO24JUNIOR
Nov 7, 2003 01:05 AM
O 16581 72452 5
Sep 18, 2003 09:37 PM
View Askew
Jul 16, 2003 12:03 PM
UncleJesse
Nov 23, 2002 04:37 PM
