utec tuners, PLEASE HELP
Old Apr 8, 2004 | 08:45 PM
K2Skier's Avatar
Car Info: 2002 WRX/STI 2.5 liter VF22
I have an annoying knock, and i can't figure out how to get rid of it! i seem to knock usually when i accelerate hard from ~4500rpm in 2nd gear into 3rd. my timing map and log are as follows:
Timing Map
[35] [35] [35] [35] [35] [35] [35] [35] [35] [35]
[30] [30] [30] [30] [30] [30] [30] [30] [30] [30]
[27] [27] [27] [27] [27] [27] [27] [27] [27] [27]
[25] [25] [25] [25] [25] [25] [25] [25] [25] [25]
[20] [20] [20] [20] [20] [20] [20] [20] [20] [20]
[20] [17] [17] [17] [16] [16] [15] [14] [14] [14]
[18] [17] [17] [17] [16] [16] [15] [14] [14] [14]
[20] [19] [19] [19] [18] [18] [17] [16] [16] [16]
[21] [20] [20] [20] [19] [17] [17] [17] [17] [17]
[21] [21] [21] [21] [20] [17] [17] [17] [17] [17]
[22] [22] [22] [22] [21] [19] [19] [19] [19] [19]
[23] [23] [23] [23] [22] [22] [21] [21] [20] [20]
[23] [23] [23] [23] [22] [22] [21] [21] [21] [21]
[25] [25] [24] [24] [23] [23] [22] [22] [22] [22]
[25] [25] [24] [24] [23] [23] [23] [23] [22] [22]
notes: during this log, i started out in 2nd gear at ~4500rpm, then
accelerated shifting into 3rd, shortlyafter i shifted into 3rd gear
i knocked twice.
4547 -7.5 2.5 10 00 00 14.7 +41.7 12.0 ECU. -6.6 ECU. 2.3
4578 -7.7 2.5 9 00 00 14.4 +41.9 12.0 ECU. -6.6 ECU. 2.3
4585 -7.9 2.5 9 00 00 14.6 +41.5 12.0 ECU. -6.6 ECU. 2.3
4655 -7.7 2.5 10 00 00 14.5 +41.7 13.0 ECU. -6.6 ECU. 2.3
4642 -7.7 2.5 9 00 00 14.4 +41.6 13.0 ECU. -6.6 ECU. 2.3
4655 -7.5 2.9 21 00 00 14.6 +28.1 65.0 ECU. -6.6 ECU. 3.1
4852 -4.7 3.6 100 10 00 rich +23.8 43.0 +22.2 -8.1 220.00 3.4
4997 -0.2 4.0 100 40 00 rich +19.2 69.0 +23.0 -6.7 220.00 3.8
5257 +6.4 4.2 100 70 00 rich +16.8 94.0 +21.0 -4.7 220.00 4.0
5420 +12.1 4.2 100 90 00 rich +23.3 86.0 +21.0 -7.1 220.00 3.9
5564 +15.1 4.2 100 80 00 rich +24.4 85.0 +21.0 -7.2 220.00 3.9
5747 +16.8 4.2 98 80 00 rich +25.4 85.0 +21.8 -7.6 220.00 3.9
6027 +15.9 4.3 99 80 00 rich +26.3 85.0 +22.0 -7.9 220.00 4.0
6150 +16.1 4.3 99 80 00 rich +26.3 86.0 +22.0 -7.7 220.00 3.9
6485 +16.4 4.3 99 80 00 rich +28.7 86.0 +22.0 -7.7 220.00 4.0
6385 +16.6 4.3 95 80 00 rich +29.3 85.0 +23.0 -7.7 220.00 4.0
6253 +13.3 3.5 0 00 00 rich +8.8 31.0 ECU. -6.6 ECU. 3.0
5910 +6.8 3.3 0 00 00 15.7 +8.8 31.0 ECU. -6.6 ECU. 3.2
5500 +1.1 3.6 34 00 00 14.2 +21.0 44.0 ECU. -6.6 ECU. 3.5
4462 -1.2 3.9 100 10 00 rich +19.7 53.0 +21.4 -7.7 200.00 3.6
4796 +1.9 4.1 99 60 00 rich +18.7 79.0 +20.2 -5.3 220.00 3.9
5065 +8.6 4.1 99 80 00 rich +20.4 80.0 +20.6 -6.6 220.00 3.9
5112 +14.5 4.1 99 90 00 rich +22.0 76.0 +20.4 -6.7 220.00 3.8
5175 +16.6 4.1 99 90 00 rich +22.5 78.0 +21.0 -7.1 220.00 3.8
5274 +17.0 4.1 98 80 00 rich +22.3 80.0 +21.0 -6.9 220.00 3.9
5282 +17.2 4.2 100 90 00 rich +22.8 80.0 +21.0 -6.8 220.00 3.8
5385 +17.6 4.2 98 90 00 rich +23.6 81.0 +21.0 -7.1 220.00 3.9
5574 +17.8 4.2 99 90 00 rich +24.4 80.0 +21.0 -7.2 220.00 3.9
5640 +17.8 4.2 98 90 00 rich +24.6 82.0 +21.0 -7.2 220.00 3.9
5717 +17.2 4.3 99 80 00 rich +24.7 81.0 +21.0 -7.4 220.00 3.9
6038 +16.4 4.2 99 80 00 rich +25.3 84.0 +21.3 -7.7 220.00 3.9
5868 +16.8 4.2 90 90 00 rich +25.6 64.0 +21.8 -7.8 220.00 3.9
5973 +16.4 4.2 38 00 02 rich +23.6 79.0 ECU. -6.6 ECU. 3.8
5931 +14.3 3.4 9 00 00 rich +37.5 28.0 ECU. -6.6 ECU. 3.0
6038 +8.0 3.2 0 00 00 rich +8.8 16.0 ECU. -6.6 ECU. 2.8
5574 +0.8 3.1 0 00 00 24.2 +8.8 16.0 ECU. -6.6 ECU. 2.9
5200 -5.7 3.0 0 00 00 24.2 +8.9 16.0 ECU. -6.6 ECU. 2.8
4803 -10.4 2.9 0 00 00 23.7 +8.9 16.0 ECU. -6.6 ECU. 2.7
4426 -10.8 2.8 0 00 00 23.7 +8.9 16.0 ECU. -6.6 ECU. 2.5
4145 -11.0 2.5 0 00 00 23.7 +11.1 16.0 ECU. -6.6 ECU. 2.3
4151 -11.4 2.1 0 00 00 24.2 +11.1 16.0 ECU. -6.6 ECU. 2.2
4100 -11.4 2.2 0 00 00 24.0 +11.3 16.0 ECU. -6.6 ECU. 2.0
Old Apr 10, 2004 | 02:16 PM
K2Skier's Avatar
sorry, didn't mean to stump everybody in here...:banana:
Old Apr 10, 2004 | 03:44 PM
boloheadrat's Avatar
You will probably get better feedback in the EM forum. As for your log, if I'm reading it right, it looks like you started letting off of the gas right before the knock event. Just do the basic add fuel/pull timing around the problem cell. Maybe you could post a WOT log as well?
Old Apr 10, 2004 | 09:10 PM
K2Skier's Avatar
it happened right before i let off the throttle, you're right. i let off the throttle because it knocked. i added .2 of fuel in my 80-100% columns from 5000rpm to red, still knocked, then added .3 and it hasn't knocked yet..."knock" on wood...
Old Apr 12, 2004 | 07:27 PM
K2Skier's Avatar
thanks for the info, but it wasn't shift knock, i have since fixed it, i was running a little lean in my 80-100% columns from around 5500 on
subaruujohn
May 10, 2013 03:50 PM
Lenmeok
May 20, 2012 02:06 PM
infulleffect
Nov 29, 2005 11:24 AM
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
