Using Premium Fuel in WRX's
Old Apr 30, 2003 | 05:11 AM
inthedeck's Avatar
if you try it...
you will run into serious knock problems, and throw a check engine light. You will get an error code, that deals with the emissions evaporation control unit.
I would suggest not using anything lower than 91, and would also not suggest putting in 89 with "gasoline boosters" as that would not be too wise.
Search for a gas station that has cheaper prices...
Later,
i.
Old Apr 30, 2003 | 05:35 AM
soso3's Avatar
Car Info: 04 FXT PSM
I run 93/94 here in Ohio....I actually filled up last Sunday at $1.49 for 93!!!!!
Old Apr 30, 2003 | 08:14 AM
sgwrx's Avatar
Car Info: 03 Sedona Red WRX
the manual also says something about ethanol and methanol mixtures, no more than 5% or 10% or something?
Old Apr 30, 2003 | 08:48 AM
SacWagon's Avatar
Car Info: 2003 SRP WRX Wagon
Originally posted by The Finn
IF the Manual says use 91 or higher, that's what you should use. Like they said, you risk potential damage and/or check lights. Not to mention a drop in power because engine managment pulls the timing back to minimize knock. Bummer...
Finn
i filled up with 87 on accident once and got on it and i could definately feel the ECU pulling timing. serious loss of power... i just babied it the rest of the tank and made sure that never happens again.
Old Apr 30, 2003 | 09:27 AM
BlingBlingBlue's Avatar
1) you bought a car with forced induction and paid around 24 grand for it. Pony up the extra 3-5 bucks to fill the tank with the gas it was designed for.
2) I haven't tried in my WRX, but with my old Saab turbo, running 87 instead of 92 not only made the car run like crap, but it was also more expensive! I got worse mileage running the 87, so much so that I was actually saving a buck or so by putting premium in the tank.
3) The manual says you can run 87 if nothing else is available. If you do, baby the car and try your best to stay off boost or you run the risk of doing engine damage.
Old Apr 30, 2003 | 10:12 AM
rjc1976's Avatar
You spent all this money for a new car...please spend the little extra to take care of your investment. On average, 93 (or 91 in some areas) octane gas is $.20 more than 87 octane. I usually fill up around 13 gallons. This translates to $2.60! For $2.60 isn't the piece of mind worth it? Especially since the manufacturer of your car is telling you that you should run at least 91? Besides, as mentioned before by someone else, you will probably get worse gas mileage. I ran 87 octane in my VW 1.8T once, and I noticed mileage and performance both suffered.
Old Apr 30, 2003 | 11:03 AM
SacWagon's Avatar
Originally posted by yellowsnow
Don't be a cheap ***. In most places Premium is only $.20 more than Regular, so over a FULL tank, which I believe is 15.2 gal, that is a difference of $3.04.
It only averages out to about $170/yr if you fill up once a week. I think most of us who own a new car can afford $170 in 52 installments.
thats a good way to look at it yellowsnow, only $3.27 a week!
the thing that sucks for me is that i work for a construction company and all the office people get free gas from our pumps in the shop, but its only 87 octane....
if i didnt have the WRX, i could have all the free gas i wanted....
but then i wouldnt have the WRX
