USDM WRX head casting question...???
Old Dec 7, 2002 | 11:22 PM
BADWRX's Avatar
Car Info: 09 E90 M3 SEDAN w/DCT
Are they the same as a EJ206 (Non AVCS) STi heads.
I am talking CASTINGS ONLY! I know that the valves, springs, and cams are different.
The reason that I am asking is because I am going to build up some heads...on the cheap...
How does STi valves, and JUN cams, JUN Ti retainers, JUN valve springs, JUN cam gears bolted up to a JDM closed deck BUILT EJ22 with a EJ25 crank sound to you...it sounds mighty tantalizing to me...
I think that it can be done for under 5 grand... A big bore EJ that can sing up on top with the best of them...I want an 8k RPM redline...my friend in AUS is running a similar setup...and his car is one bad machine.
Thoughts...and inputs on the heads are appreciated...
Andy
Old Dec 8, 2002 | 12:28 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Yes, the castings are the same.
decodeddiesel
Apr 5, 2004 04:20 PM
craiglieberman
Jul 8, 2003 04:04 PM
DarriiffftaaHuy
Mar 31, 2003 07:59 PM
Marck
Texas
Dec 30, 2002 03:07 AM
Marck
Dec 30, 2002 03:03 AM
