uppipe install Jack up engine or take out turbo??
Old Nov 15, 2004 | 04:15 PM
Smooth_Ej20's Avatar
Car Info: 2004 Wrx
This may sound dumb but i just want some clarification. So basically all you have to do to swap the up=pipe is unbolt the dp, take out the egt sensor, unbolt the passenger side motor mount and jack/push up the engine and you can get everthing out? Did i leave anything out?
Old Nov 16, 2004 | 04:54 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
1 unbolt heatshield
2 unbolt dp
3 unbolt up
4 take out egt probe
5 take off pass. side ex.manifold
6 unbolt pass side mount
7 push up motor and wiggle that sucker out
Old Nov 16, 2004 | 07:32 PM
Car Info: 2004 Wrx
thanks vibeelevin, that should make things a crap load easier.
Old Nov 16, 2004 | 09:09 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Get the 2.2ohm 1/2watt resister too
Old Nov 28, 2004 | 02:15 PM
psychobooe's Avatar
You'll have more room if you take off the intercooler. The intercooler is really to take on and off.
Old Nov 29, 2004 | 12:45 PM
Got Groceries?'s Avatar
Car Info: 2003 WRX wagon
Jack up the engine, it's easy and you won't run the risk of busting your oil line. Other misc. helpful hints:
-remove the intercooler, and one end of the pitch stop to lift the engine
-get a crow's foot O2 sensor wrench, not the straight socket type
-use PB Blaster. Not WD-40, not any other knock-off brand. The stuff is magic.
-use all new gaskets, and double up the bottom uppipe gasket if your uppipe doesn't have a flex
-remember to tighten down the blowoff valve to avoid banshee screams
Shamrocked
Sep 6, 2008 09:28 AM
Andrew
Oct 14, 2007 10:16 AM
BlackTzak
Jul 2, 2005 08:14 PM
Onizuka
Sep 11, 2004 08:22 PM
