up pipe question
Old Mar 15, 2006 | 11:35 PM
05_WRex's Avatar
Car Info: drives a STi
up pipe question
I heard it is normal for smoke to come out of the hood when a up pipe is installed? I usually have a bit coming out at frequent stops. I heard it is due to the residue inside the up pipe.
Old Mar 15, 2006 | 11:39 PM
RU-X's Avatar
Car Info: 05 wrx
it could be... or u could have a leak... if its a new car then i had the same issue, new motor smell... yumm...... if it doesn't go away within.... the next week or so i'd check it out
Old Mar 15, 2006 | 11:41 PM
05_WRex's Avatar
yeah i have a 05 rex
Old Mar 15, 2006 | 11:42 PM
RU-X's Avatar
Car Info: 05 wrx
if u just got it then thats the norm... but yea... leave it be for a week or so and if it doesn't goway then check it out
Old Mar 15, 2006 | 11:45 PM
05_WRex's Avatar
what's the worst it could happen if there is a leak?
Old Mar 16, 2006 | 10:34 AM
subie OCD's Avatar
Car Info: 04 STi
Did you use wd-40 or something to spray on the bolts during install? Thats the only smoke I had, due to it burning off...It only lasted for about an hour or two. I dont know what else could be smoking. How long has it been like that?
You would probably know if it were a leak, supposedly a leaky uppipe is really loud.
Old Mar 16, 2006 | 07:42 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
CORRECT! if you used WD-40 or any liquid wrench..thats the reason why smoke is coming out when you first start it up.
if smoke is STILL coming out after a couple days then you got a problem
Old Mar 17, 2006 | 02:06 AM
05_WRex's Avatar
another problem....
Yeah i'll be taking the car back on saturday to get it checked out to see if there is any leaks. Also another thing is when i'm at 3 rpm and decrease to 2 in 1st, 2nd or 3rd i hear some kind of rattle sound. Is this normal????
Old Mar 17, 2006 | 02:07 AM
05_WRex's Avatar
another problem....
Yeah i'll be taking the car back on saturday to get it checked out to see if there is any leaks. Also another thing is when i'm at 3 rpm and decrease to 2 rpm in 1st, 2nd or 3rd i hear some kind of rattle sound. Is this normal????
Old Mar 17, 2006 | 02:15 AM
05_WRex's Avatar
Here's the mods that i have:
HKS bov
Apexi catback
helix flex up pipe
Old Mar 17, 2006 | 05:17 AM
FULLSPECTRUM's Avatar
Car Info: 2005 OBP WRX STI
It's the the WD40. . . it will go away. . I had the same problem. . .
- mark
Old Mar 17, 2006 | 08:51 AM
subie OCD's Avatar
Car Info: 04 STi
Rattle is most likely a loose heat shield..
Old Mar 17, 2006 | 10:31 PM
05_WRex's Avatar
thanx ya'll for all of your input, i'm a noobie in this forum so i appreciate it, makes me feel better that my car is ok.
vsick
May 16, 2011 02:26 PM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
(==ImPrEzAWR==)
May 16, 2003 10:00 AM
