TurboXS RFL BOV
Old Mar 26, 2003 | 07:27 AM
SSFWRX's Avatar
Car Info: Sleeper Much?
Honestly man....im not aiming to seem like a *****, but dump that thing. Many of us have had those on our cars, and all it does is mess up your A/Fbetween shifts, and leak boost. If possible try to return it to the vendor, and get a GFB Hybrid, or run the stock BOV. The sound with the RFL is cool, but not worth the side effects.
Old Mar 26, 2003 | 09:40 PM
doubleU RX's Avatar
Is it true that RFL stands for "Real Fuc@!ng Loud"? Just curious.
Old Mar 27, 2003 | 07:28 PM
Dick Fitzwell's Avatar
it is true
Old Mar 30, 2003 | 09:17 AM
doubleU RX's Avatar
I always thought it was good because it lowered backpressure to the turbo between shifts.
Yes it is. From what I've heard, the stock one should be sufficient up to 300HP. If lower than 300HP, it's mostly for sound.
Old Apr 8, 2003 | 08:56 AM
phucvtec's Avatar
Car Info: 2003 Subaru Impreza WRX
All that I know about BOVs I have leaned today in the last 10 minutes of reading these forums One very knowledgable gentleman in a previous thread broke down the advantages of a aftermarket BOV as well as the drawbacks. Here is the way I see it so far:
factory BOV - recirculated air back into the manifold, hence the air flow read by the MAF is indeed correct (obviously)
aftermarket BOV (atmospheric) - vents boost pressure upon shifting your vehicle into the atmosphere. Pressure "spikes" occur since your turbo achieves max boost and rides along that line after about 3500 rmps. When you shift, the throttle body all but closes, and hence the pressure increases dramatically in the intake setup. A BOV vents this pressure inmmediately, reducing the stress on the turbo. Drawback? If the excess air is vented into the atmosphere, some air is lost, and hence th air flow read by the MAF differs from the actual amount of air (less then your comp thinks), hence you will momentarily run RICH (whats new? Its a subaru...). This is NOT damaging to the engine, since rich run conditions simply choke out the engine and reduce the power, but do NOT increase the temperaure too much. Wheh.
Ok, so why aftermarket BOV then?
1) sounds neat. Everyone hypes the GFB stealth FX to my knowledge, because apparantly you can adjust the sound it makes!
2) maybe, your turbo will spool up a lil quicker (debatable) and maybe you will preserve turbo life due to pressure spikes, however I find it hard to believe that Subaru would design a factory BOV that would actually ruin the stock turbo.
One last note - there are 50/50 BOVs available that vent half the air back into the manifold and half into the atmosphere, which is the middle of the road approach.
Hope this saves you all time reading up
good luck!
Old May 8, 2003 | 10:49 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
They hype it up not because you can adjust sound, but because you can adjust whether it recirculates the air or vents it into the atmosphere.
wrxisthebest
Jun 29, 2007 06:52 PM
sjwwrx
Nov 23, 2004 08:21 PM
Scooby42
Nov 18, 2004 11:56 PM
Scooby42
Wanted
Sep 21, 2003 06:20 AM
BakedCookies
15
Jan 3, 2003 11:35 AM
