Which TurboBack
Originally Posted by wvinfernovw
Helix Catted DP + Borla XR-1 Catback ($1030)
I have the TurboXS (and love it!) but the highflow cat doesnt really do anything. I can smell the exhuast as well as anyone driving behind me. It sounds awesome and fitment is perfect, I just wish it wasnt so bad for the environment.
Rumor is that the helix catted dp will pass the snffer test in CA for smog.
Originally Posted by meilers
Mixing and matching is dumb. APS 3" with a high-flow cat.
Car Info: 06 STI WRB/Gold
Originally Posted by subie OCD
Why?? A pipe is a pipe. If you get a good deal and they fit, theres nothing wrong with mix matching
The APS turboback is around $995; Cobb and other "turbo to tip" designs are a similar price. I think the Borla sounds exceptionally good, but it doesn't mate well with many midpipes, and I have no plans to spend time lying under a hot car looking for an exhaust leak. Why not go with an out-of-the-box solution...
I'm still researching and when I'm done I will buy a complete turbo-back exhaust system from one manufacturer. I figure it will make my life easier. I just have to find the right catless up-pipe, though.
there is credence to buying a complete TBE from one manufacturer, but the TXS + Prodrive is a viable option.
i say choose based on aesthetic appeal and dyno numbers.
as for me, you'd have the steal the TXS + Prodrive off of my car for me to give it up. LOL.
Car Info: 2004 wrx
hows the TXS holdin on?.. every picture i seen, they all seen to be discolorating real real bad and quick from the themal heat to almost a rusty look... is the hi-flow cat efficient enough to run on its own to pass emissions?
Can any experts comment on shiny exhausts vs discolored ones? I dont think it matters, but I dont know much about metals...
Car Info: 2004 WRX Wagon PSM
If I was getting a new exhaust, I would look at either the Cobb catted DP, or the Maddad catted DP with the faux 3rd cat eliminator connected to the factory resonator pipe and a 2.5" axleback (prodrive, etc.). I think that would be the best compromise of fit, finish, stealth, performance, and low dB's. The factory resonator pipe has a big enough diameter to handle quite a bit of power being as far back as it is (unless you want some 300+whp monster), and it smooths out the exhaust tone. The factory donut gasket with the spring bolts also allow flex in the exhaust to help prevent leaks.
Of the two you listed, I would do the TXS/Prodrive since it at least retains the factory spring bolts.
WorldONE
Engine and Drivetrain
May 28, 2008 10:51 AM
subaru_wrxwagon
Jan 6, 2005 03:35 AM
Enigma76
May 8, 2003 03:46 PM
