turbo info help
Old Feb 12, 2012 | 12:50 AM
02wrxwrb's Avatar
Car Info: 2002 wrx
turbo info help
i'm going to be getting a turbo out of an sti from a friend and have been getting different stories on what else I would need for the install.
Was wondering if i need the sti top mount as well or if the stock wrx one would be fine. and what size the oil feed line is for the 04-05 sti.
Is that all or is there more that i would need.
any help will be appreciated
Old Feb 17, 2012 | 01:08 AM
Walleye1974's Avatar
Car Info: Drochthuarach ( look it up lol ) wrx
From my understanding and info from previous threads
... if you use any other turbo other than stock you should/would use the bigger tmic which will fit your wrx. I have a 02 wrx as well and have an 08 still tmic and will be picking up a turbo in two weeks and your going to need bigger injectors imho use 550 or higher and def get a tune otherwise all those mods will be useless. Once ya do all that well can't stop there might as well so an exhaust or sway bars and make sure tour tyranny will be ok....but short and skinny use the still tmic get bigger injectors and as far as dip stick not sure on that .....hope it helps
Old Mar 8, 2012 | 07:07 AM
6SpeedBug11's Avatar
Car Info: Subaru WRX 2002
You will need, these are minimum requirements.
Sti Inter cooler of bigger
sti pink injectors or 06 07 wrx light blue injectors both flow around the same 565
Catless UPpipe fast spool and will save your turbo. Because the catted stock one has been know to blow apart and pieces of the cat will destroy your turbo.
Walbro 255 Fuel pump
A better boost controller this depends on your tuner
-Happy boosting -
Old Mar 12, 2012 | 11:59 PM
tommysyko's Avatar
I have a set if used DW 565 injectors for a wrx 2.0. Im looking for $300 cash. The kit comes with the data sheet for the injectors and he $100 rebate if you send DW your stock injectors. You should get a walboro 255 fuel pump. Bigger tmic would be good but not a must. I ran my stock wrx one until i upgraded to E85. PM me if your interested in the injectors.
Old Mar 29, 2012 | 12:23 PM
Superusdm's Avatar
Car Info: 2003 WRX
Sti Turbo
Aftermarket downpipe
Catless Uppipe
Cat back exhaust
Walbro 255 lph fuel pump
Sti pink injectors or equiv./larger
Engine Mgmt
Sti TMIC- recommended
Old Mar 29, 2012 | 08:09 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
This.....
http://www.stylinmotors.com/images/usdmsticopy.JPG
Old May 1, 2012 | 01:28 PM
o2subie's Avatar
Car Info: 2002 WRX
I have a 2002 WRX with-
K&N Intake
Perrin Turbo Inlet Hose
Titek Down Pipe
Borla Hush catback
Access Port tuned stage II
Perrin Crank pulley
I want to run-
FP 68hta
Grimmspeed ported exhaust manifold
Grimmspeed Crosspipe
Grimmspeed Uppipe
Grimmspeed Air oil separator
Grimmspeed TGV delete
Grimmspeed 3 port ebcs
Deatschwerks 850cc injectors
Walbro 255lph fuel pump
Turbo XS TMIC
Turbo XS BOV
And get tuned on E85
tall0guy
Feb 1, 2005 08:00 PM
scubieRoo
Nov 16, 2004 07:18 PM
ctdragon
Aug 31, 2003 02:11 AM
Waaa-Pst
Jun 22, 2003 06:05 PM
matt6669
May 5, 2003 09:12 PM
