View Poll Results: How do you warm up your oil?
Turn the key and GO GO GO!
5.97%
I drive very mellow until the oil is warm enough.
43
64.18%
I don't put it into gear until the oil is warm enough.
17
25.37%
I put my little sibling's hand on the heat shield. If he screams its GO GO GO!
4.48%
Voters: 67. You may not vote on this poll
Start-up, Warm-up & Go with your turbo...?
Old Jan 16, 2003 | 10:00 AM
mmboost's Avatar
I used to be one of those guys who never put my WRX into gear until the water temp was in the normal operating zone (i.e. the needle got onto the printed part of the gauge). When I got an oil pressure meter, I started waiting until idle pressure got ATLEAST below 6kg/cm^2.
Now for an educated guess... EJ20s like most modern engines do exhaust return to heat up the engine and shorten fast idle at start up, right? If this is true then the crankcase is safe to drive as soon as you turn the key, like most modern cars. (In any car I atleast wait 15 seconds to let some oil get thrown around).
So, I guess, if I start my car and just drive mellow enough that I do not start creating boost until the oil pressure is in a decent zone and water temp is up in the normal operating zone, I'm doing OK and the turbo's life is preserved?
thanx,
jason
Old Jan 16, 2003 | 10:12 AM
Zoeb2s's Avatar
I <3 White Girls
I wait until it is the normal operating range... I will not go full throttle..or even try to boost over 5 lbs until the motor has warmed up..
-Zoeb
Old Jan 16, 2003 | 11:16 AM
ScoobyBoy's Avatar
i grew up with my pops always telling me wait to until the needle starts moving. normally ill wait until the needle moves and drive slowly until it gets to driving temps.
Old Jan 16, 2003 | 11:45 AM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
I drive out of my parking stall almost immediately after the car starts (maybe 10-15 seconds of idling), but I definitely don't BOOST it around until I see normal operating temp.
Interesting note: It's a lot easier to stay OUT of boost with my newly-installed VF30.
__________________
Old Jan 16, 2003 | 01:40 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Same as most of you... Never hit boost until it reaches normal temp but I only let it idle for 10-20 seconds and then go.
Old Jan 17, 2003 | 11:50 PM
jigga's Avatar
Car Info: 02 wrx
I tend to wait until the water temp gets into the middle section before I drive off. I feel that it is a more gentle way of warming the car up. That and the fact that I don't get the annoying clutch shudder when I wait for the coolant level to hit the center zone.
Old Jan 17, 2003 | 11:53 PM
jigga's Avatar
Car Info: 02 wrx
Originally posted by DocDetroit
For me it all depends on ambient temps. In the winter I like to warm up the car for about 3 minutes before I drive. It was about 8 degrees here this moring. I think a 3 minute warm up is warranted.
In the dead of summer (ambient temps over 80) I will drive after idling for about 15 seconds.
I never exceed 3,000 RPM or more than about 1/3 throttle until the engine has reached it's normal operating tempature.
I don't have an oil temp gauge yet. Could someone who does tell me if the oil reaches it's normal temp by the time the water temp has reached it's normal operating temp (90 C)?
I have an oil temp guage on my car, and it takes MUCH longer for the oil to gain any appreciable temperature as compared to the coolant. Even with about 5-6 mins worth of idling, and another 10 mins of driving around, my oil temp only just starts to rise. It takes a bit of driving before the oil temps rise for some reason.
Old Dec 17, 2011 | 10:11 AM
1hotcorolla's Avatar
Car Info: 2010 WRB WRX
I've noticed after about 15-20 mins of driving the coolant temp gauge has this spot it hits that is just above the middle mark, it seems to sit at the middle mark for a while before bumping up to that spot just above the middle; I use that as my gauge to judge when the car is safe to romp on. I also let the car warm up for 5 mins or so first thing in the morning before leaving the house, don't typically wait that long any other time in the day after the first start up of the car, but I definitely look for the coolant gauge to hit that "sweet spot" before having any fun.
Old Dec 17, 2011 | 10:31 AM
HammsBear's Avatar
Car Info: '03 WRX sedan PSM
I turn the car on, let the fuel pump prime, then start and warm up for a few minutes, and I don't romp until it reaches close to normal coolant temps.
Old Dec 17, 2011 | 10:50 AM
You guys realize that this thread was almost NINE years old...
Old Dec 17, 2011 | 05:19 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
lots of warm ups since 2003
Old Dec 17, 2011 | 06:39 PM
nic3krnnamja83's Avatar
How do you even find this thread
Old Dec 17, 2011 | 07:58 PM
burnyou2's Avatar
Car Info: 2002 BRP 2.5RS
SCORE!!! 9 years and I'm the only one to pick option 4.
Ultimate first!
