Turbo failures
Old Jan 4, 2004 | 11:06 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
some people had problems with the first cat breaking apart and getting into the turbo. but other than that, i havent heard of any turbo failures yet
Old Jan 5, 2004 | 09:31 PM
meilers's Avatar
The absolute primary cause of turbo failure on the WRX, according to my dealership, is a break in a coolant line. Remember, the turbo is BOTH liquid and oil cooled -- and it needs it! If either coolant line gets a crack or falls off, that turbo is toast. There's no other reason for one to fail, unless you've got a manual boost controller and you are hitting 18lbs in first gear.
Old Jan 6, 2004 | 01:35 AM
hotrod's Avatar
High boost on VF22
The VF22 and other IHI turbos seem to have issues if run at high boost ( ie 18 psi) on a daily basis.
Some folks have also had "smoking" due to seal problems on them. Not sure if the seal problem is related to thrust bearing problems from high boost on not.
The mitsubishi and Garrett turbos have better thrust bearings / designs available. I'm not aware of a 360 degree thrust bearing upgrade being available for the IHI turbos.
Larry
Lowend
Mar 23, 2012 08:09 PM
JDMGC8
May 29, 2009 08:07 PM
1loudsti
Apr 17, 2008 06:33 PM
groovbusta
Mar 26, 2004 04:10 PM
singsing
May 24, 2003 03:19 AM
