turbo/BOV noob
Old Mar 10, 2004 | 09:04 AM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
It does absolutely nothing for the performance of your car except add sound. In fact you may even lose a little power, because your turbo will have to spool up to create more pressure in the intercooler that it lost to the atmosphere creating the sound. Hope that helps ....
Old Mar 10, 2004 | 11:49 AM
nic3krnnamja83's Avatar
i've heard BOV extending the life of the turbo? but u make it seem like the turbo has to work harder????
brandon
Old Mar 10, 2004 | 01:11 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
The do extend the life of the turbo, that is why Subaru uses one on the car.
Old Mar 10, 2004 | 01:22 PM
DizzyWRX's Avatar
brandon
The one Subaru uses though doesn't vent to atmosphere though, and that's why you don't get the pshshsh sound. It just redirects the boost right back to the intake, so that the turbo doesn't have to work as hard to extract air. That might be why the turbo doesn't have to work so hard. I think that's what DaWorstPlaya is getting at.
EDIT: quoted wrong guy
Old Mar 10, 2004 | 01:29 PM
Ditty77's Avatar
Car Info: 2002 WRX
Just get the BOV and sound cool already
Old Mar 10, 2004 | 01:41 PM
TurnWRX's Avatar
brandon
On the stock turbo it won't do much. On bigger turbos with higher backpressure, a bov can extend the life of the turbo.
Old Mar 10, 2004 | 01:43 PM
TurnWRX's Avatar
Re: turbo/BOV noob
Originally posted by PImprezza
Some people say putting a BOV on a stock turbo will make the car not run as well.
It'll make your car run rich = waste more gas. And sometimes an aftermarket bov can cause idle problems.
Old Mar 11, 2004 | 03:54 AM
Some dealerships will void parts of the warranty for blow off valves, due the the rich running conditions when they vent.
Old Mar 11, 2004 | 05:28 AM
theworx's Avatar
I don't think you guys are understanding what I am saying.
1. From the factory the car comes with a BOV, it's just not venting to the atmosphere. Unhook the recirc hose and viola.
2. The BOV reduces compressor surge which extends the life of the turbo, that is it's primary function, not to help the turbo stay spooled. This just happens to be the effect of having a recirc hose that plumbs back into the intake track. This is only done for reasons of keeping the originally metered air in the system.
3. In the end, running a BOV to the atmosphere to get a sound has nothing to do with performance. If you're not interested in performance and want that sound, great, I could care less.
Bottom line: If you want to keep your car running at the highest level of quality, performance, and reliability that you can, don't vent a BOV to the atmosphere.
I am finished
Old Mar 11, 2004 | 10:57 AM
theworx's Avatar
Yes, unhook the recirculation hose from the BOV.
