Tumbler Delete system ????
Old Mar 7, 2008 | 10:43 AM
turboedracer's Avatar
Car Info: 06 STi...300 Horses Slow
Question Tumbler Delete system ????
does anyone have this done to there car?? I have alittle idea what they are sort of but if someone is educated on them I would like to know what exactly the tumbler valves do and why they are there. Is the deletes system a major power up grade is there a noticable difference? Is it worth the money if im not planing to make my car a full blow race car?
Old Mar 7, 2008 | 12:56 PM
DemonPossessed's Avatar
Car Info: 05 wrx
I plan on doing mine in the future. tumbler valves help the cold start, for the first 20 or so seconds when you start in the cold. and the rest of the time the tgvs are a restriction. i think its about 10 whp and up pending on your set up. I say they are worth. but it depends.................
Old Mar 7, 2008 | 02:41 PM
subie OCD's Avatar
Car Info: 04 STi
Tumbler generator valves are part of emmisions, they are flappers that swing open and close under the intake manifold.
Here is a pic ripped from nasioc:
The top is stock and the second one is a stock one modifed (deleted), you can see that the flappers are gone.
APS makes one and there is also a JDM version....as well as manually porting and deleting the stocker as shown in the above picture. Also keep in mind you will get a check engine light that needs to be surpressed via engine management.
I bought my STi used and it came with APS TGV deletes. I also have a turbo inlet hose, TBE and a custom tune. I asked my tuner (Ed/EQ) if the TGV deletes helped and said they might have helped a little bit, maybe with response....so I wouldnt recommend it with the stock turbo. However you do need TGV deletes when you use large turbos that have 3" inlets. TGV deletes will increase top end power but it probaby wouldnt be worth it unless you have big hp goals and big turbo (plus it is a big pita to install Ive heard).
Hope this helps.
Old Mar 7, 2008 | 03:18 PM
EJ20PWR's Avatar
Car Info: 02 Bugeye STI, 07 Forester XT 18GXT-R
From what i understand, even with EM the idle is rough. If you are going to smog your car its not worth the hassle. I was thinking about doing this, and was talked out of it. Talk to a GST, or FLI they can give you an clearer picture
Old Mar 8, 2008 | 09:21 AM
unless you are making big numbers they are useless you wont notice a difference. 400+ hp is where you should even start to think about it
Old Mar 8, 2008 | 01:00 PM
subie OCD's Avatar
Car Info: 04 STi
I disagree with this, Ive had two different tuners tune my STi with the TGV deletes and my car is smoother than stock.
Old Mar 11, 2008 | 12:53 PM
EJ20PWR's Avatar
I am assuming that since the original post is in the 2.0l section that he has a 2.0l motor. From what i understand the tgv deletes make 2.0l engines run rough.
I completely agree with you that your sti runs smooth with out the tgvs.
Old Mar 11, 2008 | 02:02 PM
subie OCD's Avatar
Car Info: 04 STi
Ah, fair enough, I forgot this was the 2.0L section
Soooo......minimal hp gains, difficult install, smog implications and possible rough idle.....definitely sounds like too much hassle on the 2.0L in less you have huge HP goals (aka race car).
Old Mar 12, 2008 | 09:50 AM
exactly!
Old Mar 12, 2008 | 11:19 AM
sweet made up my mind thanks for the input guys
pt518sti
Wanted
May 2, 2007 07:33 AM
RallySportDirect
Vendor Group Buys/Specials
Feb 7, 2005 09:41 AM
giddyupwrx
Jul 22, 2004 06:58 PM
adamRmr
Jul 6, 2004 10:39 PM
