Surprising grounding mod
Old May 4, 2005 | 01:33 PM
  #32
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Hey guys,
From what I have seen, and I have been in a few autoshop classes, gone to seminars, and worked in auto performance places, and if you run a ohm test on your negative battery pole and put the other side to any ground, if there is more than .5 ohms resistance there, then and only then is there a call for more grounding. In a stock WRX or subaru I haven't seen it but I will do my car when I get home today.
Austin
Old May 4, 2005 | 03:48 PM
  #33
subywrx's Avatar
If any one thinks they got a little more horse power or smoother throttle from their grounding kit then maybe your car have a grounding problem. After reading all these positive threads about the grounding kits, I went out and purchased a $100 HKS kit. That was one of the stupidest mod I have ever done, not only I didn't feel any difference on the car, I wasted $100, could of gone to the strip club and got 3 lap dances and that I can tell you will make a difference on my horse power...
Old May 5, 2005 | 12:09 PM
  #34
illusion's Avatar
Car Info: '09 accord, '14 2 seater chevy
Originally Posted by MVWRX
Alternators are not harder to turn when you have a bigger draw on the electrical system. Alternators are mechanical systems. They spin driven by a belt on the engine.
When you can't find one, maybe you should go back to HS and stop insulting people about topics that you are clearly not very well educated on.
Uhhhh...hmmmm. Maybe you should practice what you preach. HP = (I*E*%eff) \ 746 ring any bells? Or maybe 1hp equals about 746W/M? An alternator is in essence a DC motor. Yes it's current potential is static(at a given RPM), but it's voltage driven device. A regulator is used to control how much of a drop is seen on the diode bridge, which in turn shows a drop across the coils on the stator. If you pass an open ended coil across the magnet there will be no attraction(aside from the normal magnetic attraction). The greater the load on the coil, the greater the force that is needed to move the coil across the magnet . In an alternator, the greater the voltage difference between poles(the bigger the load) the more current will flow, and the more work the alternator must do. The faster the coils are passed across the magnets, the more potential the alternator has. So with your theories an alternator magically takes this rotation with no parasitic loss and makes energy? And it's RPM independent? Hmmmmm wonder why the voltage tends to sag at idle. Too bad your theories aren't correct, that would be cool, a never ending source of energy.
You shouldn't be so fast to pounce on people when you in fact don't have all of your ducks in a row, so to speak.
Old May 10, 2005 | 10:22 PM
  #35
2bluewagons's Avatar
Car Info: 2004 wrx wagon
Originally Posted by sigma pi
i did it and b4 my car would shake like no other if i was in 5th grear at 40mph and now it rocks no shaking
Because I always run at 40 mph in 5th. Wait, this car has a fifth gear? This thread is turning into the kind that we all laugh at, and sigma pi nailed it early on. At least, I hope he was joking...
"After reading all these positive threads about the grounding kits, I went out and purchased a $100 HKS kit. That was one of the stupidest mod I have ever done, not only I didn't feel any difference on the car, I wasted $100, could of gone to the strip club and got 3 lap dances and that I can tell you will make a difference on my horse power..."
Further proving the point: it works for some, not for others. The science of how good the end of a nasty curve feels at WOT is not as simple as Ohm's law and efficiency of elec generators.
Old May 16, 2005 | 06:45 PM
  #36
DriftinS14's Avatar
Car Info: 02 WRX, 06 A3
Saying that a ground is a ground is just as dumb as saying a DIY kit cant compare to the big name ones. Different types of materials put together using different methods have very different electrical flow characteristics. I worked professionally in the home theater field for many years and I would always get those "electrical engineers" telling me that "cables theoretically cant make a difference" those same engineers were usually 60+ years old, using a 1982 Marantz Stereo reciever and a set of 12" cerwin vegas, because it sounds "just as good as the new fancy expensive stuff". Electrical current travels smoother with less drop on the surfaces of conductors, that is why you can get a 16 gauge speaker cable that has thousands of tiny hair like strands that has twice the performance then a cable over 3 times its size. What you CAN say is electrical flow is electrical flow. The more effecient and cleaner the flow, the better performance you WILL get.
Now with that being said im not saying these kits will make a difference im only commenting on the idea that there can be a difference between the kits.
_justin
Old May 16, 2005 | 07:59 PM
  #37
Impooter's Avatar
this is silly, illusion is right, grounding kits are good, its not like a type-R badge, its actualy doing somthing, less interference, lower ground resistance due to thicker cables and less distance for current to flow (metal has its own resistance, less wire or distance, less resistance) , without a doubt frees up horsepower, screw dyno results, they cant reliably measure somthing that small, but i garuntee you there is SOMTHING happening, especaly in an older car with ****ty wiring, BIG difference, and a DIY kit will do just fine if your connections are made properly in the proper places with a good guage wire, hell it will even benefit on a newer car, not as much, but there will be significantly less noise in your electrical system and less load on your alternator and goodies like that which will free up some horsies....its silly to say a mod thats so electricaly drastic makes no difference, plus, those people with 128 strand wire in the shape of a pyramid pointing to venus ARE electrical engineers trying to win an audio competition, where using the "proper" wire just wont cut it anymore, thats like racing with a stock motor...it just wont cut it if you wanna move up a class, so what do you do? anything you can to make it just a bit better..squeezing out just 1 more dB is worth it to them if they have to use insanely high tech wire, just like .01 more G's on the skidpad is worth it to a track attacker, that extra .01 can really drop lap times...
Old Jul 8, 2005 | 04:23 PM
  #38
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
Questions for those with the DIY gounding kit.
- What are the sizes for the connectors? 10mm? 12mm?
- Any wire shield melting issue?
- From what I have read so far, just some 4 AWG low impedance, high strands (>700 strands) oxygen free, copper wires right?
- Sound like gold connector and solder (oxygen free) the connector to wire are definitly plus. Anything else?
thanks!
Old Jul 8, 2005 | 04:35 PM
  #39
laoba's Avatar
Car Info: rx8
i'm getting this soon. a friend was having electrical problems on his sti while on dyno-tuning, thought it was kit. disconnected it, turns out it was something else. reconnected it, along with a 5hp increase.
Old Jul 8, 2005 | 05:28 PM
  #40
scottzg's Avatar
Car Info: 34k and 5 sets of tires
Originally Posted by Flash N Dash
The Hyper Ground system from Sun Auto was one of the first companies to do these mods in Japan and they are one of the few that are a PROVEN product. Many magazines have tested this system on a number of different cars and EVERY TIME there was an increase in power. Skeptical or not it works. And you DO NOT get the same results from a do it yourself kit as you would this. . . . blah blah blah. . .
This kit from Sun Auto is proven on the WRX to gain around 7-8 HP. FACT.
If anyone is interested in getting one of these kits let me know!
I love it.
1FSTREX
Dec 21, 2010 09:57 AM
batmanalan
Nov 19, 2003 10:14 PM
kartune
Jul 8, 2003 06:50 PM
TheRedWRX
Feb 22, 2003 08:45 PM
Peaty
Dec 30, 2002 10:41 AM
