Surging Idle and Low Boost
Old Feb 22, 2013 | 06:07 PM
redtangent's Avatar
Car Info: 2003 Surbaru WRX
2003 Subaru with 170,000 miles on it. Don't drive it much these days, just on weekends. Was running great until about a week ago, now the idle, when warm, surges a bit, maybe 100 rpm and the vacuum would jump from 18 inHG to 14 inHG, back and forth. At first the car still drove normally. Now I can only hit 7-8 PSI of boost. There is a hesitation when it revs off idle too it seems.
My guess was a vacuum leak (I think 20 in hg is normal), but i can't find anything, none of the lines look bad. I know i have the 'pill' installed. I did have an aftermarket BPV installed but replaced it with the stock one, no help. I reset the ECU but no help. Also cleaned the MAF, might have helped the issue a bit, but still getting lower than normal boost and a surging idle, but both possibly are better than before
There does seem to be a noise coming from the intake/TMIC area, possibly a leak, but the hoses are in decent enough shape
Idle Air Control Valve maybe? Just drive it more now that i cleaned the MAF?
Thanks!
Edit: Thought car info was in my profile, 2003 WRX, TBE, Catless UP, TXS UTEC w/ Pro tune and Streetlite flywheel
dthack03
Apr 23, 2014 08:02 AM
DetailAddict
18
Nov 26, 2007 11:56 AM
fastfamilywgn
Apr 30, 2006 09:42 PM
HoFaiWRX
Mar 8, 2003 07:56 AM
