Stromung Midpipe
Old Feb 14, 2004 | 10:03 AM
CRAWLWRX's Avatar
Car Info: 2003 WRX Sedan
Stromung Midpipe
I just installed a stromung midpipe to my 2003 wrx w/prodrive axleback. I have a leak at the donut gasket at the 3rd cat. Is it normal for that gasket to leak a bit, or could i have a defective midpipe. I could not find a new donut gasket anywhere. The original seems to be fine, only 7500 miles. Does any one have any suggestions?
Old Feb 14, 2004 | 04:29 PM
Uncle Scotty's Avatar
Did you re-use the spring bolts?...are they tight? Is the joint straight?
Shoulda got the Stromung axle back
Old Feb 14, 2004 | 04:55 PM
CRAWLWRX's Avatar
Yes I reused the spring bolts, tightened them till the threads stopped. joint seems to be straight. Is it normal for a small amount of air to leak thru? I'm not real happy w/leak, reworked the fit 3-4 times.
Old Feb 14, 2004 | 05:55 PM
You may need a spacer behind the donut gasket to push it out a little to make better contact with the seat on the midpipe. I had to do this, and the answer was a 1/8" piece of exhaust pipe of the size to just fit behind the donut.
Old Feb 14, 2004 | 06:03 PM
CRAWLWRX's Avatar
Hey thanks for the reply. I'll give it a try.
MaX_WRX
Jan 26, 2015 10:04 AM
GnarSTi
May 20, 2014 05:26 PM
02eugeneRS
Jun 25, 2003 09:13 AM
AWD_Dan
Apr 17, 2003 08:55 PM
mexicanpizza
Jan 21, 2003 09:19 AM
