STi RA Spec C Motor ?s
Old Mar 7, 2004 | 08:45 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
I haven't been able to find any information on the motor that comes in the car. Any info or sites I can find info on it would be great! I'm looking for info on the turbo, block, IC, etc...
Thanks,
Chris
Old Mar 7, 2004 | 10:35 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
there is a little info here:
http://www.rallispec.com/
I have seen a few sites in the past few weeks on some Type RA stuff.
You might do a search for Litchfield Imports (in GB)....they import the RA Spec C into England.
Too bad we can't buy that car here!!
You cruise Highway 35 much out your way?
Old Mar 20, 2004 | 12:42 AM
Axis Power Racing's Avatar
Version 7 uses forged pistons.
Version 8 does not.
Both have nice treated cranks. Beefy semi-closed deck.
RA Motors have large intake ports on the cylinder heads. Flow ~260CFM on the intake side stock.
Version 7 Motors used the old VF30/34 technology, where as the version 8 uses a twin scroll set up.
Version 7 still have TGV, altho they are free flowing. Version 8 uses a 1 piece intake manifold.
Different oil pan, exhaust manifold (equal length), oil feed lines, cooler, and twin scroll turbo and matching up pipe. Has a different designed dowpipe with o2 sensor right after the turbo housing.
VERSION 7 RA Spec C
VERSION 8 RA Spec C
-Mike
www.axispowerracing.net
Old Mar 20, 2004 | 09:05 PM
jimr's Avatar
The turbo-induction hose on the V7 looks large, is it something special for the RA?
Old Mar 22, 2004 | 09:37 PM
Arnie's Avatar
Car Info: WRX Wagon
It seems that the intake manifold is a bit different between the two as well. The V8's red pipes seems to reach deeper to the block compared to the V7. Is this correct? WDoes anyone thing there would be compatibilty issues between using the various STI intake manifolds and the various blocks?
Old Mar 22, 2004 | 09:56 PM
AWD 20T's Avatar
Wow nice observation. I too would like to know more...
Old Mar 22, 2004 | 10:07 PM
I noted that.
Each manifold will work fine. Just the version 8 went back to the old skool technology. The manifold itself will still bolt on say your US STi or WRX just fine.
-Mike
greenpoop
Jul 9, 2009 08:31 PM
FLIWRX
Engine and Drivetrain
Apr 30, 2007 01:27 PM
c279a
Oct 26, 2006 04:07 PM
View Askew
Dec 25, 2003 08:32 PM
