STI IC in WRX, how well would it fit?
Old Apr 7, 2005 | 01:41 PM
lugee's Avatar
Car Info: o4 PSM WRX
I was wondering about the install of a STI ic into a WRX, is it a perfect fit or would i need to do some modification to the AC hoses?
are there any alternatives to the sti IC?
Old Apr 7, 2005 | 03:11 PM
porkchop's Avatar
Car Info: some silver thing
it's gonna be pretty tight, but it fits, just make sure your AC lines don't rub against the IC...
almost all of the after market TMICs are bigger than the STi IC.
Old Apr 8, 2005 | 08:01 AM
WRX2ndregime's Avatar
Car Info: 2005blackwrx5spd
I have one for sale $350, it fits well, but it's not as good as the stock in the fact that you can get it, in and out very easily. you need to loosen brackets slightly and tighen them up to get everything into place. The hardest thing to get fit right is the red pipe from the turbo to the intercooler inlet. you need to adjust that just right so it comes together properly.
Old Apr 8, 2005 | 01:07 PM
subywrx's Avatar
FYI: Installing a STi I/C first slip in the red hose tighten it first then the big throttle hose, find out to be easier this way.
Old Apr 16, 2005 | 04:57 PM
dElKwOn's Avatar
Car Info: vf-34'd ewg'd GDA AMS tuned!
itll fit but its gonna be tight . if your getting just the i/c without the hose kit . try to give rallispec.com a look . i got my hose kit from them for $ 150 when i got my jdm sti tmic .
Old Apr 17, 2005 | 12:42 AM
lugee's Avatar
i should just buy a larger IC when i get a new turbo. thanks for the input everyone.
Old Apr 18, 2005 | 10:49 PM
STi-owns-evo's Avatar
Car Info: '02 PSM WRX
Don't the stock WRXs have a mounting bracket already there for the STi IC? Isn't that what the small bracket is jutting out on the passenger side of the IC?
Old Apr 19, 2005 | 12:25 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
Yes
Old Apr 21, 2005 | 07:04 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
From what I have heard it is not a bracket problem it is a hosing problem and as said before can be fixed with the kit from rallispec.com
Rush
STINGR4
24
Jan 28, 2016 05:12 PM
stealthrex68
Apr 10, 2007 06:25 PM
_sti_05
Oct 28, 2004 10:36 AM
doubledeuce189
Aug 20, 2003 07:59 AM
