stage 2 and intake
Old Mar 16, 2004 | 07:08 PM
wrx10404's Avatar
Car Info: 04' wrx
stage 2 and intake
Does anyone have a stage two with anything other than a stock intake? I checked with cobb and they recomend the stocker. I have a UNI filter ram pod and i don't know what to do. Any suggestions would be appreciated. Thet said that it may lean out the engine too much. Also if you recomend using the stock intake give me some ideas about filters, delete elbows and such.
Edit: Cobb said that aftermarket intakes tend to lean out the motor. Along wiht the leaning that thier stage two does in some spot this could hurt the motor.
Old Mar 17, 2004 | 07:08 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I have the same intake (I bought it before learning about this site) but I took it out after all of the negative feedback (on all intakes) I got from a thread I posted here. I didnt want to risk haveing any problems because of it so I reinstalled the factory box and did the silencer removal @ http://www.scoobymods.com/forums/sho...?threadid=3268 I didnt add this piece because I didnt know about it but it looks like a good idea. I do miss the sound of the intake and I would think the leaning problem could be fixed by some custom tuneing (which would probable stop you from doing the reflash or acces port). So I will leave it out because I plan on doing Acces port. Cobb told me the same thing.
Old Mar 17, 2004 | 07:40 PM
wrx10404's Avatar
Car Info: 04' wrx
I am going to remove my intake a put the stock box back on. I am goig to buyt that delete elbow though. Just safer that way. I wish the stock intake box looked a little cooler though. I may paint it or something. Luckily i bought my rampod used so i'm not out alot. I may try to sell it(with a disclaimer of course). I was very happy with it and it caused me no trouble until now.
Old Mar 17, 2004 | 08:23 PM
Wingless Wonder's Avatar
Origami posted by wrx10404
The stock intake works. It hasn't proven to be a restriction with most street-driveable mods. The aftermarket intakes (CAI, short rams, whatever) will likely induce an MAF mis-reading and the ECU tries to compensate, resulting in a screwed-up air/fuel ratio. These intakes can be custom-tuned to smooth things back to normal but it can take up to an hour of dyno tuning, with little or no gain in power.
There's a 'sticky' thread listed on this forum page about intakes.
Old Mar 17, 2004 | 09:13 PM
MO REX's Avatar
Would it be expensive to have car tested (or can it be done?) to see if a particular intake is induceing a MAF mis reading because Unifilter claims that it will not and if it didnt would it be safe to say it wouldnt run lean? The only reason I ask is because I really like the sound and according to Unifilter it filters much better than factory filter.
Old Mar 17, 2004 | 10:25 PM
Pay for a couple of AWD dyno runs at nearly any shop with a wideband 0² sensor. If you have the time, try to do back-to-back runs on the same car using your Unifilter and the stock airbox. That's the only way you'll know for sure that there's a difference.
It's also possible that a given intake will not lean out an engine enough to cause any damage. All that's known for certain is that the stock airbox won't cause problems. There's also a misconception that a slightly leaner mixture is better for power, but while this may be true under certain conditions, MAF errors make a torque curve much more jagged with lots of peaks and valleys. Intakes are not a good way to tune cars.
Old Mar 18, 2004 | 07:53 AM
Egan's Avatar
My car is running a safe 340 crank hp on the stock airbox and filter (I did hack the silencer).
As you will read in many threads, most major tuners do not recommend intakes for the reasons you described. In addition, unless they have a CARB sticker on them, aftermarket intakes are illegal here in Kalifornia (land of smog *****).
Speed Element
Mar 20, 2009 01:32 PM
STi_Mark
May 3, 2008 06:17 PM
Cend_wrx
Apr 5, 2003 12:03 AM
mattr762
Mar 26, 2003 11:47 AM
pillaka
29
Dec 1, 2002 01:14 PM
