snapped timing belt 2002 wrx need help
Old Jun 1, 2012 | 12:23 PM
wagonrasa's Avatar
Car Info: 02 siver wrx wagon
Thumbs up snapped timing belt 2002 wrx need help
Hello
I was driving in 5th gear and my timing belt snapped. Shop I took it to said that my valves might be bent. Said it would cost 5000 to fix. I was wondering what route I should go to keep my baby running. Its a 2002 wrx with helix up pipe and down pipe 120k on the motor. Was thinking about maybe getting a replacement motor. Don't want to spend 5000 if possible. I live in Honolulu HI so shipping is a problem.
Old Jun 1, 2012 | 12:35 PM
Alliedforces86's Avatar
Car Info: FR-S + WRB Bugeye.
Yeah you've probably got some damaged valves and possibly a few pistons. But for 5k you could buy a jdm STI engine and swap it in if you can do a lot of work yourself. Good luck whatever you do, but you engine is most likely screwed. If you can come across and wire camera to snake into the spark plug area and check the piston heads to see which ones hit valves.. An idea anyway..
Old Jun 1, 2012 | 01:15 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
yep.. swap with sti..your baby has taken you this far already..120K..i think it deserves a good o Ej25.. haha
Old Jun 1, 2012 | 01:23 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
i dont think theres a a way around it. Its going to cost 5k, at least..
Just look at your options.
Rebuild the EJ205
Swap an EJ257 longblock
Swap an EJ207 longblock
maybe even 2.2T
puma_man
Apr 17, 2014 11:36 AM
unstble
Mar 21, 2008 09:09 AM
