smoking turbo
Old Dec 13, 2003 | 04:32 PM
international B's Avatar
Chewwwwy
check the oil feed line ontop of the turbo. i had this problem also and thats what the cause was.
Old Dec 14, 2003 | 12:32 AM
Wingless Wonder's Avatar
It's probably an oil leak from the feed line. The turbo runs almost as hot as the exhaust system so any oil on the outside surface burns up. The oil line supplies lubrication for the turbo's internal bearings.
You'll have to remove the heat shield before you can clearly see what's going on.
EDIT: See this thread.
Old Dec 18, 2003 | 10:17 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Don't be scared to go to the dealer about the full exaust, all they will tell you is that having the full exaust might, stressing might, void a few, also stressing few, warrenties pertaining to exaust manifolds and S.M.O.G. work. Nothing to do with turbo or its oil feed. No fear, they smell fear. Go in raging and tell them what is on your mind haha. Good Luck
WRX Rush
Old Dec 18, 2003 | 11:15 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
prolly just the top banjo bolt on the turbo, make sure its tight. If it is, you might want to replace the copper crush washers ( top and bottom )
Old Dec 19, 2003 | 11:18 AM
mmboost's Avatar
It could also be a coolant leak. What's the color and scent of the smoke? If its sweet and white, its very likely to be coolant.
jason
phunhawg98
Jan 8, 2014 11:11 AM
bao ling
Sep 8, 2003 02:32 PM
aloose
Jun 8, 2003 04:30 PM
EtchyLives
May 17, 2003 11:21 PM
ted1186
May 3, 2003 09:57 AM
