reseting ECU after mods..
Old Apr 19, 2004 | 10:05 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
hey, i hear that we are supposed to reset our ECUs after each mod... How is it beneficial? if it is, how do i do it? thanks guys.
my bud has some bolt ons and he's never reset his ECU...
Old Apr 19, 2004 | 10:41 PM
escaflowne's Avatar
does resetting reset milege?
Old Apr 20, 2004 | 01:02 AM
ScoobyBoy's Avatar
reseting the ecu pretty much makes the ecu relearn everything instead of waiting for it to slowly adjust.
a search will give you alot more info.
Old Apr 20, 2004 | 12:23 PM
DrKicker's Avatar
Car Info: 2002 WRB WRX
Quick rundown. Disconnect negative side of battery, press brake pedal until taillights go out. Reconnect battery. Drive aggressively for the next 50 miles for a more aggressive learn. I made a huge difference to do this after my downpipe was installed.
Also, it only resets your trip odometer.
Old Apr 20, 2004 | 12:29 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
You could also perform the "Vishnu Reset" that will instantly max out the timing advance so you don't have to wait for learning. Search for how to do it, it's pretty simple.
Old Apr 20, 2004 | 01:39 PM
awns729's Avatar
Car Info: want a WRX
Well, driving aggressively for the first 50 miles probably yeilds similar results, but the vishnu way is most likely quicker. If you do reset it the only way you'll notice a power difference is if the ignition multiplier retarded timing due to knock(bad gas), otherwise AFAIK there shouldn't be any noticable difference.
oh and if the timing has been retarded and you do the vishnu trick it will advance the multiplier to + 12-i think (default after reset is 8, vishnu trick increases it)...search for the vishnu advance multiplier trick which has all the info you need.
Old Apr 20, 2004 | 07:14 PM
escaflowne's Avatar
thanks guys.
Old Apr 20, 2004 | 07:15 PM
awns729's Avatar
so what are you planning to do?
edit: once you do it, let us know how it tuns out
Old Apr 20, 2004 | 07:21 PM
escaflowne's Avatar
i have my cat. getting my up and down soon.
Old Apr 22, 2004 | 07:17 AM
ride5000's Avatar
don't reset too much.
become accustomed to the feel of pulled timing... flat spots in the torque curve. they are your clue as to where knock is occuring, and that something isn't quite right. resetting your ecu to "cure" the problem puts your engine at more risk, since the knock will likely happen again, and it must before the timing is accordingly re-pulled.
your ecu will ALWAYS attempt to advance the IAM, and it will slowly readvance the learned knock zones... resetting just helps it along its way.
in case you haven't noticed, i am of the persuasion that the least amount of resetting the better. in the case of a bunch of modding to open intake/exhaust, then go ahead an do it.
jm2c
ken
i<3dirt
Oct 20, 2014 10:26 AM
Turbo86
Sep 18, 2005 08:06 PM
anthonymx
Feb 15, 2004 11:50 AM
awns729
Jan 28, 2004 02:40 PM
spdkills
Feb 12, 2003 12:37 AM
