reseting my ecu?
Old Sep 18, 2005 | 10:22 AM
Turbo86's Avatar
Car Info: 2003 WRX Sedan
reseting my ecu?
i just installed a helix downpipe and a stromung catback exhaust yesterday and i was wondering if i should re-set my ecu?
if so where is it located, how do i go about re-setting it, and how long can i drive the car without re-setting it?
thanks
Old Sep 18, 2005 | 11:24 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Yes, unplug the negative side and step on the brake a few times leave the battery disconnected for a half hour or so.
Old Sep 18, 2005 | 11:25 AM
slvrsubywgn's Avatar
thanks
You don't need to reset it, but I guess if you would like to start from "scratch" and let it re-adjust itself you could. I think it will automatically adjust itself around your new parts after a tank or two of gas without resetting anything. But if you'd like to, disconnect your negative battery terminal and step on the brake pedal a few times and that should reset it. I leave my battery disconnected for about 10 minutes just to make sure.
Old Sep 18, 2005 | 02:33 PM
Turbo86's Avatar
i actually had the battery disconnected the entire time of the installation and we actually did tap the break a few times, so all in all everything should be okay.
thanks for the help guys, btw the car is sounding better than ever
Old Sep 18, 2005 | 06:18 PM
blue blurr's Avatar
brake*
Old Sep 18, 2005 | 08:06 PM
Turbo86's Avatar
Originally Posted by blue blurr
brake*
hah, my bad.
escaflowne
Apr 22, 2004 07:17 AM
blueberryrex
Apr 17, 2004 02:25 PM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
anthonymx
Feb 15, 2004 11:50 AM
awns729
Jan 28, 2004 02:40 PM
