Remove silencer CEL?
Old Jul 28, 2004 | 10:46 AM
lllRedline's Avatar
Car Info: 03 PSM WRX stg 2
I'm considering removing the intake silencer on my 03 and I've read that doing so can throw you a CEL. Is that true? If so, how can I reset the ECU if I do get a CEL without going to the dealer?
Old Jul 28, 2004 | 11:08 AM
WRX_2NR's Avatar
Car Info: 04 WRX
I've just removed my silencer on an my04 and I had no CEL's
I don't think you'll have any problems
Old Jul 28, 2004 | 11:46 AM
SuzWRX's Avatar
Car Info: 2005 Aspen White Subaru STI
I removed mine and never had a check engine light, you shouldn't have any problems, and if you do just throw it back on, its really easy to remove and install.
Old Jul 28, 2004 | 12:21 PM
RoadSpike's Avatar
The cels happen on the downpipe where you mess with the o2 sensors and cats.
The silencer shouldn't affect this
Old Jul 28, 2004 | 12:24 PM
lllRedline's Avatar
awesome thanx! I just wanted to be cautious cuz someone posted something about cel's on scoobymods regarding this issue.
http://www.scoobymods.com/forums/showthread.php?t=113
Old Jul 28, 2004 | 01:41 PM
Alizarin's Avatar
Last note, if you don't reset the ECM you will get a CEL. The flow character IS different and apparently the MAF notices that something has changed. However, once the ECM is reset there is no CEL.
That's from the Scoobymods post... I don't really think that's true, since you're changing the flow before the airbox itself. The air exiting the airbox and past the MAF should still be in the same flow pattern. I didn't reset my ECU after I took it out and got no CEL at all.
That's actually the first I've ever heard of a possible CEL after removing the silencer... at least for a WRX.
Old Jul 28, 2004 | 03:11 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
I have never heard of a time where removing the silencer threw a CEL
Old Jul 28, 2004 | 03:17 PM
mmboost's Avatar
you won't get a CEL, but your muffler bearing fluid might dry up fastAr.
jason
Old Jul 28, 2004 | 03:23 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
I HAD A CEL AFTER REMOVING THE SNORKUS!!!!!!!
but it was from a fracture in my sparkplug. hehe
Old Jul 28, 2004 | 07:27 PM
Uncle Scotty's Avatar
If you get a CEL from removing the silencer, it is because you borked something along the way.....most likely you would not get the airbox cover back on properly or you borked the MAF harness/plug somehow....
bsuby36
Dec 11, 2005 09:20 PM
esracer
Mar 16, 2004 11:56 AM
namitherussian
13
Feb 28, 2004 07:53 AM
mlane1
Feb 26, 2004 06:20 PM
Daremo
Aug 20, 2003 12:56 PM
