Recommended turbo
Old Nov 11, 2006 | 09:10 AM
Teddy's Avatar
Car Info: Subaru JDM Type RA
Recommended turbo
Hey wats a recommended turbo for makin at least 450 hp on the EJ20. Here's the deal i've recently installed a JEMS ecu which was giving me about 28 psi on the stock turbo, but i have a big boost problem, and i realize the actuator is releasing the pressure to early, was wonderin if the PE1820 woulf be a betta application turbo for the operation, along with upgraded injectors and a FMIC........thanx
Old Nov 12, 2006 | 10:52 PM
testes1010's Avatar
not sure what a JEMS ecu is....but that way too much boost pressure for any normal bolt on turbo....
the PE1820 is overpriced & overrated plus it more than likely won't get you to your goal of 450hp(assuming crank hp, not wheel hp)
what model year is your car, moreso engine code? if you are running a EJ205, anything over 375-400chp will seriously lessen your engine life.
for 450chp, I'd recommend going rotated w/ a Ultimate Racing T3/T04E kit....going rotated will save you money in the long run.
subaru046
May 30, 2003 09:01 PM
Boost Addict
25
Apr 29, 2003 01:05 PM
BluWrX.03
14
Apr 3, 2003 05:14 PM
iratika
Mar 25, 2003 01:51 PM
plunk10
Feb 25, 2003 06:14 AM
