rattling/grinding sound and 'stutter' in 1st gear (was: Two Issues...)
Old Sep 24, 2007 | 08:38 PM
Jebb209's Avatar
Car Info: 05' AW STi
I just bought my 05 WRX and I've had a noise I'm unsure about... The sound is pretty apparent and only happens when the car is slowing down in gear (under compression) and mostly in third gear. I hear a rattling/grinding coming from the transmission area. It could be a heat shield or something worse... Anyone have similar issues?
The other problem is when I punch the throttle in firs gear I get almost a studder as it runs from low to high rpm's. I don't know what turbo lag feels like but it very well could be it. Anything?
Also could anyone recommend a nice cat-back exhaust and blow off valve for an 05 WRX? I just want a little sound out of this thing!
Thanks yall!
Old Sep 24, 2007 | 08:53 PM
VRT MBasile's Avatar
did you buy it in private sale or from a dealership? if you got it from the dealership I'd bring it back to them and ask them to look at it.
as far as a CBE, it really depends when youre looking for. If you want something thats a little louder and a lot deeper at idle, but has the ability to scream at WOT, go with the borla hush. If you want a BOV sound, go rent Need For Speed Carbon.
congrats on the new car though, and welcome to i-club
Old Sep 24, 2007 | 11:17 PM
Jebb209's Avatar
I bought it from a dealership and they did look at it and the report said that they moved some heat shields... Then I drove it and couldn't make the noise again. Of course after a few miles the sound was back! I love the car... So much fun to drive but this sound is killing me!
Old Sep 24, 2007 | 11:33 PM
go back and kindly ask them to move more heat shields you can also ask them to go on a test drive with you so that you can try to make it make the sound
Old Oct 4, 2007 | 11:27 AM
NDzToYCaR's Avatar
Car Info: Subaru impreza WRX aspen-white
....or being devil's advocate
it can be something worse. If you bought it from a dealer i would def. do what these people suggested - take it back. if you having chatter at low rpms worse case could be a LOOSE FLYWHEEL. i've seen it happen, as a matter a fact experienced it. what you describing sounds like it. BUT AGAIN that is WORSE CASE. you might want to get that checked
Good Luck
Old Oct 22, 2007 | 10:59 AM
calvinahhh88's Avatar
Car Info: 04 WRX (sold), 03 WRX (sold), 04 330CI (current)
i have same experince but on a 03 WRX only happens when im downshifting or when i let g the gas pedal on the freeway couldnt figure it out...
Old Oct 23, 2007 | 03:39 PM
JDMWrx04's Avatar
Car Info: subaru wrx 2004
could be wastegate flutter if it does it while decelerating. have the dealer adjust the wastegate
Old Oct 23, 2007 | 07:10 PM
mickieD67's Avatar
Car Info: 05 protuned stg2+ wrx
i have an 05 wrx and i get the wierd deceleration whine/grind also, mostly in 1st and 2nd gear and a small bit in 3rd. Ive read a couple forums that this is normal, but i have a feeling thats BS. Im to the point where i avoid decelerating in 2nd. I am first going to change the tranny and diff fluid and if that doesnt help then ill probablly get it checked out. Il let you know wat i find out
juniorsti
Jul 20, 2007 08:14 PM
Randman
13
Mar 6, 2007 09:23 AM
WRXWagon203
Jul 5, 2004 10:58 PM
boosted
May 30, 2004 06:46 AM
muhon
13
Oct 2, 2003 04:34 PM
