Quick question...Lil Help
Old May 19, 2004 | 01:20 PM
Daredevil's Avatar
im not to keen on boost creep, but i do know that it means it goes over the desired limit, perhaps harming the car
boost spike is when, under WOT and your boost is set high as it is or you have a crappy boost controller, it will Spike over the limit real fast, sometimes caushign fuel cut if it is over 17psi
hope this helps
btw, i could ways be wrong, so you should use the search feature
Old Jun 16, 2004 | 01:50 PM
DJTEN4's Avatar
Car Info: 03 yellow wrx
blitzs sbc id and ported wastegate = no boost issues
808subaru
Oct 16, 2008 10:22 PM
HaYnGaMeShOoTeR
Nov 12, 2003 10:26 PM
jiveturkey
Nov 12, 2003 02:57 PM
Steppin Razor
Oct 23, 2003 08:41 PM
stg2lgcy00
Sep 17, 2003 10:07 PM
