quick newbie question about headers
Old Mar 28, 2004 | 10:58 PM
BoxerRumble's Avatar
Car Info: 2005 STi Silver
what are they? i understand as of now that they are part of the exhaust system, and i read somewhere that they are just a system where the exhaust, burnt up oil and air from the engine, are released into the piping into the air. and i thikn the header is the part where the exhaust's first step into going outside the car, and it is tubes for each cylinder to do so, and it converges into one pipe and heads down to the downpipe and catalytic convertor and stuff, but whati dont get is ..what is the difference between a normal header, if there is such a thing, and a performance header system, or between no header and a header.
Old Mar 28, 2004 | 11:20 PM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
I think you're asking "What's the difference between a header and an exhaust manifold?"
You've got it right for the most part, the header/exhaust manifold collects exhaust gasses from each cylinder and merges them into one pipe.
Someone else can pick up where I left off...
(explaining the above question and the equal-length header stuff)
Old Mar 29, 2004 | 12:25 PM
NluvwithXLR8ing's Avatar
check it out http://www.scoobymods.com/forums/sho...?threadid=1575
High perfomance headers will have less restrictions and better air flow for more power.
Old Mar 29, 2004 | 01:54 PM
wrx21's Avatar
Car Info: 2004 Impreza WRX
Exahust manifolds are usually Cast iron and are one peice .. Headers are tubes welded together and attached to a flange to bolt to the block. Also, on a WRX the pre turbo exahust system is not to shabby. If your car is not modded in regards to exahust you should start with a Cat Back .. High Flow Cat or Midpipe .. Downpipe .. and Up Pipe. Do a search in some other threads to learn more about all of that. Anyways a header is somthing you won't probaly see any gains in hp if you are still stock, plus its a pain in the a** to put one on.
Hope I helped out a little more
-John
Old Mar 29, 2004 | 11:06 PM
thanks everyone for the reply, and i get it now, thanks to everyone of course. oh and yeah, i just wanted to know because i love cars, but i do not own one myself, lol, sad i know.
brucelee
Aug 1, 2009 10:59 AM
808subaru
Oct 16, 2008 10:22 PM
dunnojack
Nov 30, 2006 01:53 AM
wrxgti22
Jan 7, 2006 10:07 PM
redenzo
Mar 12, 2004 09:43 PM
