Question for u guys
Old Mar 9, 2004 | 08:08 PM
KDamericano's Avatar
Car Info: 2003 WRX
I haven't heard of too many people throwing a cel from a turboback. Most come from the uppipe. Most every turboback will either have a bung for the 02 sensor or a resistor fix. Not a real big problem. Just my .02
Old Mar 9, 2004 | 09:19 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
once you remove the cat after the turbo, you will throw a CEL. get a cel fix from gruppe-s.com
a cat-back will not cause you to throw a CEL
Old Mar 9, 2004 | 10:17 PM
WuWrx's Avatar
if you get turbo back, you will get CEL from removing the "cats" on the downpipe, you can get cel fix from this website:
http://www.ponyexpressperformance.com/index.html
Old Mar 10, 2004 | 01:30 PM
DizzyWRX's Avatar
I just wanted to add, i got a cel after installing my turboback, even though i have the high flow cat. There are cel fixes though. I did the mechanical fix myself, but after getting rid of the cat inefficiency code, i got some other o2 sensor low voltage code, so maybe my rear o2 sensor is just f'd up.
Old Mar 10, 2004 | 03:09 PM
wrx10404's Avatar
Car Info: 04' wrx
Re: Question for u guys
Originally posted by Ponjoob
i wanna put in a down pipe, mid pipe and cat back but i dont want my cel light to come on is there any way to avoid it. or should i just go with the cat back..............
Do a search fro cel fixes on i-club. You will see many threads. I had a CEL from my turbo back. WRXncrew hooked me up with a mechanical fix and i have no cel's now.I don't like messing with my factory harness some people do not care. Go with a turboback you won't be sorry.
Old Mar 10, 2004 | 10:41 PM
anthonymx's Avatar
when i got my helix downpipe it came with a cell fix and i have no cats and it hasnt thrown a cel
nycphilly
Aug 16, 2005 03:37 PM
BoxerRumble
May 23, 2005 10:06 PM
gbmotorsports
Sep 5, 2004 01:11 PM
AWJunkies
Mar 29, 2004 12:23 PM
dr3d1zzl3
Mar 16, 2004 10:16 PM
