Problems
Old Mar 21, 2004 | 12:41 PM
02wrbluewrx's Avatar
Car Info: 2002 WR Blue WRX
Angry Problems
Okay so I just installed my Perrin uppipe and Bosal downpipe and I have a Scooby Sport midpipe and catback. My problem is that lastnight was doing about 120 with a G35 coupe and my car felt like it didnt want to go any faster. It felt like the turbo was boosting on and off. I'm pretty sure I don't have an exhaust leak but I might be wrong. Also it stalls a lot at lights but thats cuz its running rich right?......Maybe I'm wrong please lemme know what you think..
Thanks,
Andrew
Old Mar 21, 2004 | 01:44 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Im no pro but I wouldnt think those mods would make you run rich because I dont see anything that would add fuel to the mix. Maybee it would be a good idea to reset your ecu. I dont know that it would work but its worth a try since you added all of those exhaust mods.
Old Mar 21, 2004 | 01:49 PM
How do I reset my ECU??? And would I be boosting on and off because I am running rich???
Old Mar 21, 2004 | 02:09 PM
GottaREX's Avatar
Car Info: 02 WRX
Yes, reset your ECU. Just unhook the neg batt cable then press the brake pedal a few times until all the memory is erased. Plug it back together and your good to go. I also think you're having boost spikes when you said the turbo spools on and off. Either you have the 3/16 restrictor mod done, or you have a CAI or Short ram filter, these things will do that to your car. Trust me, I've done all of those and at the end, I'm sticking to the stock restrictor hose and the hacked stock air box. No more boost spikes for me. BTW, your next mod should be the AccessECU stage 2, just got mine last week. I got the same mods you have, and the car runs like a champ. Goodbye stock EVOs and G35s. :banana: :banana: :banana: Actually got to run with my friends stock STI too and we were about the same.
Old Mar 21, 2004 | 02:15 PM
esracer's Avatar
Car Info: 2002 Honda S2000
Sorry to hijack alittle....but what exactly is a boost spike? What happens etc.
Old Mar 21, 2004 | 02:25 PM
MO REX's Avatar
Here is a thread to do a quick learning trick https://www.i-club.com/forums/showth...&threadid=6413 if Gotarex's way doesnt work (Im sure it will though). Keep us posted and good luck.
Old Mar 21, 2004 | 02:26 PM
GottaREX's Avatar
Car Info: 02 WRX
It's exactly what the name says, spiking of boost. You'll know when you're getting boost spikes when you hit the max boost and the turbo isn't able to hold it, so it spikes up and down, making your car feel like your pressing and depressing the gas pedal when you're not.
Old Mar 21, 2004 | 02:27 PM
MO REX's Avatar
Im pretty sure its when your boost will hit a high # then suddenly drop off.
oops looks like we posted at the same time but you are much quicker.
Old Mar 21, 2004 | 02:34 PM
GottaREX's Avatar
Car Info: 02 WRX
Originally posted by MO REX
oops looks like we posted at the same time but you are much quicker. [/B]
It's all good
Old Mar 21, 2004 | 03:15 PM
I dont have 3/16 nor aftermarket intake I just hacked the stock one too.....but this doesnt sound like an exhaust leak to anyone? And I think I'm gonna go with a UTEC...
Old Mar 21, 2004 | 03:38 PM
MO REX's Avatar
Did you try reseting the ecu? If not it only takes a minute. Always start with the most simple solution, see if that works then worry about exhaust leaks.
Old Mar 21, 2004 | 03:43 PM
Ya thats definitely what Im goin to try and do thanks a lot.......also I dont know if this has happened to anyone else but when installing my up/dp a couple of those little vaccum hoses broke cuz they were so brittle maybe its just because I have 66,xxx miles on my car......kinda off topic but oh well
Old Mar 21, 2004 | 04:29 PM
MO REX's Avatar
Broken vacume lines will almost definately cause you problems so if you didnt replace them do so then reset ecu.
Old Mar 21, 2004 | 07:15 PM
No I replaced them I was just saying...
Old Mar 23, 2004 | 09:26 AM
Alright just ran down the expressway and that reset seems to have worked thanks a lot everyone..
Andrew
