Power gain from up-pipe install
Old Jun 21, 2006 | 12:11 PM
Hurucan's Avatar
I drive an '05 WRX wagon. I currently have:
TurboXS turboback
Prodrive axleback
TurboXS UTEC
as power mods.
What would I gain by upgrading my up-pipe? What other power mods should i look into?
Old Jun 21, 2006 | 01:13 PM
MacMan2.0's Avatar
Car Info: 04 WRX waggon ShortShift Boost Gauge
I've seen advertised gains of 15hp...But an up-pipe is more about the spool.
Deffinetly a good mod.
Old Jun 21, 2006 | 01:26 PM
Hurucan's Avatar
Spools faster due to more airflow?
That makes sense.
Cool - thanks for the quick response!
Old Jun 21, 2006 | 02:22 PM
sylencce's Avatar
Car Info: 04' WRX Silver Scooby
An up pipe is great mod for a subaru. Especially since it takes the pre-cat out. Check out the reviews section and look at a few options. Helix has a good one and I love it and there are a few others that are good as well, but the big point is you'll get all the feed back from everyone as to why they switched.
Old Jun 21, 2006 | 04:05 PM
mudman's Avatar
From: Stop drag racing a rally car, and you'll be OK
Car Info: WRX STi
Go to ebay and search on "wrx gutted up-pipe" and you'll find a guy who takes a stock up-pipe and professionally guts them, he then sells them for $80, plus when it is fitted he'll buy your original up-pipe back off you for $40.
The benefit of this is that if you ever have to go to state ref, it will be undetectable, you don't want to have to swap up-pipes too many times as it's a PITA.
Performance will be exactly the same as an aftermarket up-pipe and the fit is factory perfect.
Old Jun 21, 2006 | 06:40 PM
RysingSun808's Avatar
Car Info: 2004 Subaru Wrx
installing an up-pipe you should notice more low end power off the bat. it was pretty obvious for me.
Old Jun 22, 2006 | 08:19 AM
Hurucan's Avatar
And once I have the up-pipe done, what should I look into next (with regard to power mods)? Turbo/pump/injectors? Bigger TMIC or FMIC?
Old Jun 22, 2006 | 08:25 AM
scarface's Avatar
Car Info: 2005 WRX STI
STi has the catless uppipe. Just my 2 cents
xicema17x
Jul 25, 2005 07:54 AM
wvjnky
Nov 20, 2003 04:05 PM
SpecWRX
Nov 10, 2003 11:05 AM
genmaster
Jan 8, 2003 09:52 PM
newbaby
Jan 7, 2003 10:51 AM
