which IHI turbo gain more hp
Old Jan 7, 2003 | 12:55 AM
Nolimit's Avatar
Where is my beer?
Car Info: NSX, G35
... you're asking in the wrong Forum btw.
Old Jan 7, 2003 | 05:53 AM
nqwan's Avatar
Car Info: o2 duburu arr exu
Re: which IHI turbo gain more hp
Originally posted by newbaby
Hi there,
I'm going to upgrade the turbo for my 02 wrx, Can u guys tell me which IHI turbo can gain more hp and more top end hp? Is all IHI turbo can bolt on to my wrx without mod? Thx!!
the vf series should bolt on with no trouble. the vf22 is biggest of that family. it may not be a good idea to just buy the turbo only, you'll want larger injectors, fuel pump and definitely some sort of ecu management.
Old Jan 7, 2003 | 10:51 AM
Rexstang's Avatar
First 12sec WRX in HI
Car Info: 12.93@106.71
Very true, if you replace the turbo you will want to get bigger injectors and pump to deliver more fuel to match the increased airflow. Also a good engine management system will allow you to get max efficiency out of your setup.
All VF series turbos are direct bolt on.
The VF-22 can push the most air but comes at a heavy price IMHO, lag. 3,800 rpm's is a long time to wait for boost. But once it hits, hell yeah. If you want a smoother powerband the VF-30/34 will hit full boost around 3,200 rpms and the VF-23 will hit it around 2,800 rpms.
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
JDMGC8
May 29, 2009 08:07 PM
gruppe-s
Vendor Group Buys/Specials
Oct 8, 2004 10:09 PM
PogiMarky
Oct 20, 2003 12:36 AM
K2Skier
Feb 17, 2003 05:47 PM
