Power cut out!
Old Mar 20, 2003 | 04:37 PM
jigga's Avatar
Car Info: 02 wrx
The "power cut" you are feeling is fuel cut... Obviously, your ECU is not happy with something, and I think that it might be the lean condition that the header produces if no tuning is done. You will most likely need to get your unichip reflashed for the header as well......
Old Mar 21, 2003 | 04:49 PM
jigga's Avatar
Car Info: 02 wrx
Hmm... I'm not sure why it does this only in first gear, but what I know is that you definitely should not run an aftermarket manifold without engine management to take advantage of them.
Perhaps your ECU is not able to adjust fuel/timing with the revs climbing so quickly in first gear, but you definitely are hitting fuel cut.. I hit it before, and it is not a pleasant feeling, especially when you are in the middle of an overtaking manouver...
get your unichip tuned for your header (which will cause your engine to run lean without tuning), and I am sure you will have no probs.....
Old Mar 21, 2003 | 05:13 PM
jigga's Avatar
Car Info: 02 wrx
hmm... I guess it could be your fuel pump...not sure though... Thing is that you are taking a different upgrade path than most people do around here. Most get the header as the very last thing... after the turbo upgrade (which is supported by STi injectors, and a 255lph fuel pump, and engine management) and the upgraded intercooler, etc.... It is my opinion though that you might be overtaxing the stock fuel system though with your mods and the aftermarket manifold
From what I remember, Vishnu's Stage one package is good for around 230WHP.... Headers for around 10-20WHP with tuning... Thing is that the stock fuel system is only good for between 240-250WHP, so you might be at the ragged edge of what the stock fuel system can give. You might want to think about upgrading to bigger capacity fuelpump, and STi pink injectorssooner rather than later with the manifold in place.....
note that you will need your unichip remapped for the injectors as well since the stock ECU will not run the car properly with them in place...
ouji
Jun 2, 2010 09:44 PM
RU-X
Mar 12, 2007 12:45 PM
dunnojack
Nov 14, 2005 05:13 AM
SHADO
Apr 28, 2004 02:02 AM
pacobeagle
Jun 16, 2003 03:10 AM
