PLEASE HELP 0 boost after install...
Old Mar 2, 2003 | 08:01 AM
BakedCookies's Avatar
Car Info: 2002 wrb wrx
Yesterday I installed perrin uppipe perrin downpipe and Apexi exhaust, everything went very smooth, took about 5 hours, i did both the egt and the o2 cel fix with the supplied resistors, i cranked the car everything sounded normal except the new helicopter like sound coming from the exhaust, let the car warm up in the shop no leaks, just some smoke from the turbo which im sure was from the huge amounts of penetrating spray i used, so i take the car out, driving down my block, press the gas build a little boost, maybe 3-4psi, get out on the main road, drive down through the 35 zone then punch it, no boost, the car drives fine but will not build boost at all, i hear no leaks or anything odd under the hood, I am guessing Im either in Limp Mode, or i have a leak somwhere in the hoses to the IC, anyone have any ideas, I think i was able to rev the car as normal, but dont remember because it was late... PLease give me some advice, I am going to check the egt cel mod, the maf sensor, and the intake hoses today... if I am in limp what do I do...??
TIA
note*** i am throwing no codes... no check engine light
is the wastegate stuck in open dump?
note2 **** car revs to regular redline, but still no boost, its almost like the wastegate has gotten stuck, is it possible if the perrin downpipe inside baffle for the divorced wastegate was slightly bent, could it have "caught" the wastgate and is holding it open, because mine has a slight dent in that piece when i got it... I have checked the egt mod, i actually clipped the plug off and soldered and heat shrinked the resistor in place, i have checked all the intake hoses, and the BOV both are sealed tight, i have disconnected the battery for 15 minutes, still no changes, when i did the install i unplugged the primary o2 but plugged it back up before cranking the car initially is this ok, or could that have caused a problem? I have triple checked all my work, i need help ASAP, i have to have my car so i can get to work tommorow.... PLEASE HELP...
Old Mar 2, 2003 | 02:32 PM
BobbyD's Avatar
the wastegate could be stuck on the splitter inside the perrin dp..
--bobby
Old Mar 2, 2003 | 04:27 PM
Stevied's Avatar
Car Info: 4 wheels
Originally posted by RalliTeK
Sounds like the wastegate actuator is disconnected.
Sean
If the wastegate was disconnected you'd get too much boost no?
Old Mar 3, 2003 | 05:20 AM
heres what happened
My wastegate splitter was damaged in shipping, but i did not think it was enough to hurt anything, I was wrong, the wastegate was stuck open on the splitter, so i tapped the splitter back into shape and grinded and sanded out the raised areas(it looked like a crumpled fender, thanks ups ) reinstalled the donpipe and hand tested the w/g a few times.
Everything is fine now, but honestly overall, im not to impressed with the performance gains i have received from the uppipe downpipe and exhaust, they are mediocre or worse yet non existant... any opinions on why?
Old Mar 3, 2003 | 11:58 AM
yes
from totally stock to these 3 mods in one day... I must admit, driving the car today seems to be alot more impressive... would it be wise to go with say a turboxs mbc and set boost to 15psi? or should i just wait and go with utec or vishnu
Old Mar 4, 2003 | 10:51 PM
Try resetting your ECU. Chances are when you first drove it the car was still trying to figure out what was going on with all the weird inputs. Since it got better today, and knowing that Subaru ECUs adapt fast, you may not need to now.
i<3dirt
Oct 20, 2014 10:26 AM
Subistrong
Oct 18, 2007 11:17 PM
huck
17
Feb 3, 2004 02:52 PM
subawho?
Jan 26, 2004 06:50 PM
spdkills
May 23, 2003 09:41 AM
