Optima Red Top Battery?
Old Aug 19, 2004 | 01:41 PM
spectra's Avatar
Car Info: 2003 WRX Blue
I am thinking about getting an Optima Red Top Battery but I don't know what model number I need to get. Do you have to modify the battery tray? And do I have to extend the Battery Cables to reach the Polls on the battery? Any help would be great.
Old Aug 19, 2004 | 03:58 PM
spectra's Avatar
I orderd my Otima Red Top Battery just now at "Remy Battery". I got the 35R or on there site is was the 35-925. I got it for $89.44 after shipping great price. Here is the link if anyone wants it. http://www.remybattery.com/350/shope...ies&subcat=166
Old Aug 20, 2004 | 07:22 AM
Danno_man's Avatar
Great price!!!!
i've had a red top in my Discovery for 8 years now, and it's still going strong.
Old Aug 23, 2004 | 08:24 PM
SuperHawk's Avatar
Car Info: 2006 WRB Wagon Ltd.
I just returned a Red top to Costco because the cables in the WRX for the Power wire is to short! Even with the little metal clip disconnected it was to short.
So good luck maybe yours is different than the one at Costco
Super
Old Aug 24, 2004 | 02:28 PM
CharT's Avatar
Car Info: 2003 WRX Wagon
I think Costco only sells the 35. A 35R will have the posts reversed so that the positive and negative terminals switch places. You shouldn't need to extend your cables if you get the 35R.
Old Aug 24, 2004 | 03:15 PM
Mulder's Avatar
Car Info: 02 WRX WRB
You probably got the "universal" model 35/75 which has both the top post and side terminals. On this model the posts are more toward the center of the battery and the positive cable to the starter is a few inches too short to reach the positive post.
Although the regular 35, or 35R as it may be called, is preferable as a drop-in replacement since it works with the existing cables, the 35/75 can be used. It's not an insurmountable problem. For about $5 from just about any parts store, you can get a replacement "starter to switch" cable of the proper length (29-30") and swap it with the OEM one.
I bought the 35/75 from Pep Boys two years ago and at that time AFAIK the 35R wasn't available. Changed the cable and it's been fine ever since.
Other than the terminal arrangement, both batteries are physically the same size and electrically identical with the same specs.
Old Aug 24, 2004 | 03:50 PM
Lowball's Avatar
Car Info: 02Wag on 17's
I looked at Optima and then decided on Odyssey PC680 Drycell (15.4lbs). Have had zero problems even with the car sitting for over a two week time period. www.odysseyfactory.com
Old Apr 30, 2005 | 02:21 PM
wickedrex's Avatar
I clicked on your link and it showed up item # 35-910. You stated that you got the 35-925 on there site, but I look and still couldn't find it. I went to the local store today and they tried to install the regular 35 Optima Red. They said it wouldn't fit because the oem wire is too short. They said I will need to look for the 35R (which is what you have). So should I just go ahead and order the 35-910?
Old May 1, 2005 | 09:57 AM
knightsnke's Avatar
Car Info: 2003 WRX
yeah don't get the wrong one otherwize u need longer battery cables and its a pain in the ***, i had the red top one, it was not worth the hassle
SeaOfGreen
Aug 15, 2011 01:51 PM
BugeyeMilo
Hawaii Classifieds
14
Apr 2, 2008 02:47 AM
dorifto88
Dec 17, 2004 12:00 PM
jjunior887
Jan 18, 2003 04:38 PM
