oil filter?
Old Jan 7, 2006 | 03:05 AM
Detritus's Avatar
Car Info: 2005 CGM WRX
oil filter?
I bought an oil filter for my 05 wrx from the dealer today. The one they gave me was white where as all the ones I had bought before from dealers were black. Did they change the color or did the parts wench give me the wrong one?
Old Jan 7, 2006 | 08:46 AM
04whitewrx's Avatar
Car Info: 2004 wrx
the part numbers changed from a 15208aa080 to a 15208aa09a. if the 09a filter is the one you have, be careful because suabaru has had problems with them leaking. after changing your oil, check to make sure your oil filter isn't leaking after a couple of minutes. it won't leak bad, but in my opinion, any leak is bad enough. if it doesn't leak, you're done. if it leaks, then they have another filter for you. part number 15208aa100. that filter is replacing the leaking ones.
Old Jan 7, 2006 | 09:34 AM
i use denso 150 1006
they are big like teh older style. the black one is from japan and the white is USA.
Old Jan 7, 2006 | 01:12 PM
Detritus's Avatar
Its the 09A, guess I'll just have to make sure its not leaking. Thanks for the replies.
fd777
Jun 12, 2010 09:05 PM
nation
Apr 17, 2009 01:16 AM
JackHCChen
Nov 12, 2005 09:50 PM
wrxout
Oct 26, 2005 03:13 PM
