Oil changing info
Old Apr 28, 2003 | 08:26 AM
soso3's Avatar
Car Info: 04 FXT PSM
Unhappy Oil changing info
I've been reading the other threads about oil changes/weights/syn vs. regular and now I really worried...
I just changed my oil at 1,040 miles (after keeping the RPMs below 4K and varying the RPMs) to Mobile1 Full syn 10W-30....I've only driven about 150 miles since...
Did I just f**k up?? According to some posts in the other threads, I should have waited until 3,000 miles to do the 1st change and then not to syn until at least 6,000 miles....
Any opinions?? Should I change my oil back to non-syn??
Old Apr 28, 2003 | 10:46 AM
soso3's Avatar
Hey! It's Shamrock again....I used 10w30 because my stupid *** wasn't paying attention when I bought it (and because that what I always put in my other cars - so when I saw 10w30, I just went for it.. )
So you aren't concerned about the *special additives* in the oil from the factory that help break in the *hardened* sleeves??
Old Apr 28, 2003 | 08:21 PM
hotrod's Avatar
Not a problem be happy
It's not a problem. Most of the breakin of the piston rings ( which is the issue on synthetic's) occurs in the first few hours of running. That break in continues to mature over the next several thousand miles. A WRX with 20,000 well cared for miles has more power than one with 200, or 2000 miles for that reason.
The synthetic is a good investment, and will give you much better hot weather protection, and significantly inprove the life of the engine.
As far as the 10-30, in the summer time that should be no problem, you may want to drop back to the thinner recommended weights in sept, but it will not cause a problem of any kind. The 10 refers to how easy the oil flows when the engine is cold, the 30 refers to how thick the oil is when the engine is hot. There is no important difference between 0-30, 5-30 and 10-30 oil once the engine is hot. You will only see a slight difference in cold weather starting and a very slight change in fuel milage when the engine is cold.
Larry
Old Apr 29, 2003 | 08:20 AM
soso3's Avatar
Talking
Thanks for the input!!
I feel much better now....
Old May 7, 2003 | 03:31 PM
fastnoypi's Avatar
my opinion and has worked for me..is to use reccomended 5w30 for up to 2-3 oil changes during/after the break in.
I've spoken to and seen many wrx owner with blow-by oil problems that they fill their catchcans or sludge their throttebodies full of blow by oil. ...definitely a sign of improper break in.
Blow by was very minimal on my old wrx motor prior to swapping
Old May 7, 2003 | 07:31 PM
roreswrx's Avatar
it doesn't make any difference alot of the cars come from the factory with mobil-1 fill already. you shold also put some synthetic oil in your trany in another 1,000 mi. or so i put red line MT-90 in mine big difference works alot better now. Thomas
Old May 10, 2003 | 11:46 AM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
when i had a cracked oil pan i took it to the dealer for some warranty work, they said that they put in 5-30 normal oil, i had told them that i had always used synthetic on the phone before this and they said that that was not good for subaru engines as they are designed to run with normal oil, they also said that they may deny warranty work if anything ever happened to my engine while using synthetic. were they just telling me a load of crap?
by the way, this was my old dealership, the same people that quoted me $500 base to put in an act clutch, just labor, i bought the clutch, bearings, etc. by myself and the same dealership that said it would cost over $500 for a 4-wheel alignment cause my wheels were too big and they had to charge something like 1.5hours labor for taking wheels off and another 1.5 for putting them back on
Old May 10, 2003 | 10:47 PM
philioWRXman's Avatar
Car Info: 1998 Chevy S10... lowww
i work at a "jiffy lube" place, but we are the number one oil change shop in the bay area.
i actually did a test on motor oils, for my school's required science fair, and which work better.
i used all of the oil weights Castrol makes, and the weight above the weight recommened (10w-40 and 10w-30, respectively) was all around better. better fuel ecconomy, better protection against viscosity breakdown, etc.
and the 10w-40 was not synthetic. it did better in all categories than the Castrol Syntec oils did.
hope this info helps a bit.
wrxdriver
May 9, 2004 07:37 PM
BlueSti389
14
Feb 12, 2004 09:09 AM
SHADO
Dec 15, 2003 12:15 AM
BongMan
Jan 13, 2003 11:18 AM
