oem boost controller wont boost past 10 psi
Old Dec 4, 2004 | 12:35 AM
rollinDAwrx's Avatar
Car Info: 2005 WRX Black
wait nevermind it is a seperate plastic peice. i found it on my car. should you be able to blow through it easliy or hard?
Old Dec 5, 2004 | 10:07 AM
vaj's Avatar
vaj
Car Info: 2004 Big Booty STi with a two finger gap.
The little restrictor I have is a metal orifice. I was able to see inside the other lines and you should be able to as well. The restrictor goes right next to the nipple on the compressor side of the turbo.
HOWEVER, I am still having this problem and am continuing to research it. Obviously 10psi is the base wastegate pressure so something is still not right for both of us. Check out the Vishnu Performance Forum here @ i-club for the continuing saga....
y2Ldude
Mar 27, 2009 01:59 PM
tayna1
Jan 1, 2007 12:36 AM
SilverRex04
20
Nov 23, 2004 05:50 PM
slammin
Dec 25, 2003 11:28 PM
Spool_up
Mar 25, 2003 10:41 PM
