Octane Booster
Old Sep 6, 2004 | 02:28 AM
2Stroke's Avatar
Car Info: 2003 WRB Wagon
Originally Posted by RussB
you'd be better off finding a pump with 100 octane unleaded and mixing that in.
Yup, or finding a paint store with 114 octane toluene and mixing that in.
Old Sep 6, 2004 | 01:40 PM
icantdrive75's Avatar
Car Info: 2004 Black WRX -- RIP
Originally Posted by excessive03
The stock car cuts boost to 9 psi after 5k rpms so what you are seeing is totally normal for a stock car. If you want the car to make boost after 5k and make real power you have to get a boost controller. A boost controller will hold it at what ever psi you set it at within reason for the small turbo. My car makes a little below 15 psi after 5k and slowly drops as rpms build and the stock turbo runs out of steam. My car made 252hp to the wheels at 6850 rpms with this set up. At 6k where the car used to die it now pulls to redline so hard sometimes I shift late at 7200 rpms .
With just a boost controller?
Old Sep 6, 2004 | 06:02 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Be careful going this route that you don't become too ambitious. It's very easy to overboost if the EBC is not set correctly. Plus, I don't think it's just an EBC that allowed you to put out that much power; surely you have other mods?
Old Sep 6, 2004 | 06:15 PM
That's what I was thinking. I don't plan on using a boost controller. I'd rather go with the vishnu packages. It seems alot safer.
Old Sep 18, 2004 | 06:50 AM
t-wrexxx's Avatar
My ball-valve type boost controller maintained 15psi in 1st, 2nd, and 3rd gears. Even after 5000 rpms.
Old Sep 18, 2004 | 07:12 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
... with 100 octane unleaded and mixing that in. but if you're able to get 92 octane, that's pretty good stuff as is.
That's great for those of you with higher than 91 gas. In Colorado, 85 is regular, 87 is premium, and 91 is super. Nothing higher.
Old Sep 19, 2004 | 11:06 AM
illusion's Avatar
Car Info: '09 accord, '14 2 seater chevy
You don't have any magic 76 stations in CO?? In cali we have the crap gas ratings and even the 91 octane is oxygenated 91 so even that detonates if it's a bit warm out(although we do 87,89,91). Thanks to the regional forums here I located a single local 76 station with 1 pump with 100 octane, the blessed pump #10. Thankfully it's only about 1/2 mile out of my way so I've been making a habit of a single gallon of 100 octane with my fillup and she runs like a champ with a 91 octane map loaded in my AP, and even happier with 3 gallons running the 93 octane maps.
GotBoost?
Dec 22, 2003 05:41 PM
gpatmac
Sep 29, 2003 12:50 AM
gpatmac
Sep 25, 2003 03:19 PM
Ash
Jul 3, 2003 12:42 PM
cobraKLR
Jan 23, 2003 12:31 PM
