No Boost
Old Apr 26, 2007 | 10:09 AM
blaxon's Avatar
Car Info: 2002WRX
No Boost
My car (2002) all of the sudden has no boost. The car runs fine (slowly) and no CEL. I have a unichip. Is this a common problem with a simple solution or something I need to take to someone?
Thanks for any help.
John
Old Apr 26, 2007 | 02:47 PM
Jake's Avatar
might want to take it to GST they can probably help u oops ure located in LA
Old Apr 26, 2007 | 06:49 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Is the car literally running 0 PSI or is boost just low? Do you have a boost gauge?
Old Apr 27, 2007 | 04:15 AM
blaxon's Avatar
Car Info: 2002WRX
0 boost, I have a boost gauge and it never gets to zero (always negative).
Old Apr 27, 2007 | 06:31 PM
MO REX's Avatar
Did you check the vac lines and wastegate arm? A hose could have popped off or the C clip that holds the wastegate arm might have rusted and broke off. If boost was on target and I lost boost all the sudden I'd guess it was the WG arm.
One more thing. Are you hearing any unusual noises?
Old Apr 27, 2007 | 06:40 PM
blaxon's Avatar
Car Info: 2002WRX
Thanks, I will check those in the morning.
Old Apr 28, 2007 | 08:41 PM
MO REX's Avatar
Any luck?
Old May 5, 2007 | 08:31 PM
blaxon's Avatar
Car Info: 2002WRX
Nothing I could see, I guess I will take it somewhere.
Thanks again.
Old May 6, 2007 | 11:23 AM
MO REX's Avatar
Before you take it in run a vac line from the wastegate solenoid to the to the compressor outlet (turbo). This will eliminate the FBC and you should be able to run between 7-8psi (wastegate pressure).
Old May 16, 2007 | 03:01 PM
blaxon's Avatar
Car Info: 2002WRX
Mo Rex- thank you for your input and I apologize for not getting back sooner. I wasn't to sure what you were saying to do so I was taking it to a local shop and right before I arrived, my boost returned (that was yesterday) and everything seems fine. Maybe the wastegate was stuck open or something. I'll have to wait and see if it happens again.
Again, thank you,
John
Old May 16, 2007 | 11:56 PM
turbosmurf02's Avatar
Car Info: 2006 Evo IX SSL
did u make sure your uppipe wasnt clogged? (the 02's come catted up the ***)
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
