NGK 1 step colder?
Old Oct 13, 2008 | 06:23 PM
bmxhotsauce's Avatar
Car Info: subaru
NGK 1 step colder?
i just got some for my 02 wrx can someone help me out with the gap size i need please
Old Oct 15, 2008 | 08:39 AM
willow's Avatar
Car Info: wrx02
I think NGK iridium comes pre-gaped - within subaru spec.
Old Oct 15, 2008 | 09:12 AM
03_Impreza_Al's Avatar
http://forums.nasioc.com/forums/showthread.php?t=518633
Old Oct 17, 2008 | 03:52 PM
stg2lgcy00's Avatar
I usually gap my 1 step colders at .028
Old Oct 17, 2008 | 04:00 PM
YOU ARENT SUPPOSE TO GAP THEM!!!!
if you gap them you screw them up
the platinum gets scratched off or the iridium is screwed
run stock plugs
Old Oct 17, 2008 | 06:55 PM
run stock plugs
woops I guess I did that wrong
Old Oct 17, 2008 | 09:05 PM
Wingless Wonder's Avatar
How to install spark plugs on a 2002 WRX. Proper gap is necessary for correct ignition system operation. Don't assume spark plug gap is correct even on spark plugs specified for your car.
EDIT: Only the side electrode should be adjusted for proper gap. Do not touch the center electrode. Even a scratch can alter the voltage requirement to fire the spark plug and cause a high-speed misfire under heavy acceleration, especially on cars with modified tuning (more aggressive ignition advance, higher boost pressure).
Old Oct 18, 2008 | 09:57 AM
how do you think i learned hahahhahahahahahaha
its cool this is the hard way
i like to learn that way sometimes haha
snowflow
Dec 28, 2010 12:01 PM
inspire420
Hawaii Classifieds
17
May 20, 2010 11:47 PM
ScoobyWho?
May 10, 2010 06:06 PM
simontempler
Hawaii Classifieds
13
Feb 3, 2009 09:45 AM
Konrad_WRC
Feb 22, 2006 07:06 AM
