Newbie question (how to run low-12 or high-11 seconds)
Old Feb 13, 2004 | 05:04 PM
meilers's Avatar
Trying to convince a 3,200 lb AWD car to be an 11-second dragster is an expensive and (IMO) misguided idea. There is a reason that there is no official AWD drag class, like there are RWD and FWD drag classes: that extra drivetrain is costly in weight and loss of power due to friction and heat. You'd be much better off buying a used Camaro SS or Corvette and turning that into a 10-second car, and it would save you thousands of dollars, if not $10k or more.
I just checked an ad in the paper, '98 Camaro SS for $11k. Do an engine swap, exhaust mods and a supercharger and it would still come in under $16k and beat any WRX in a straight line.
Old Feb 14, 2004 | 09:10 PM
Uncle Scotty's Avatar
Save yourself ALL the trouble and don't even start with a WRX....it 'AINT worth it.....trust me.
If you just GOTTA Subaru...save your pennies and get an STi so you don't have to spend all that $$$ on what the STi already has.
A WRX just 'aint worth it....
Old Feb 14, 2004 | 09:57 PM
KINGSKY's Avatar
Car Info: GC8 ej20 motor, 18" gramlights on yokos,
if i were u i'd get the the GC8 then do a motor swap. it's lighter plus i think it looks better than the WRX.
i did. can't wait to get it tuned......
RANDi
Old Feb 14, 2004 | 10:45 PM
RANDi
Subarus are bad bases for drag cars. They have disadvantages you have to spend too much time and money overcoming.
Old Feb 15, 2004 | 12:23 AM
ilivas's Avatar
FP 18g turbo-www.forcedperformance.net-$750
Ultimate Racing Injectors 785cc-www.ultimate-racing.com-$425
Turbo XS UTEC-www.turboxs.com-$1049
Walbro 255 lph fuel pump-www.forcedperformance.net-$99
Helix Down Pipe-www.ebaymotors.com-$255
Helix up pipe-www.ebaymotors.com-$130
Turbo XS FMIC-www.turboxs.com-$1499
Turbo XS shorty intake-www.turboxs.com-$159
Autometer Boost Gauge 30 psi/30 in hg vac-www.ebaymotors.com-$43
Autometer EGT gauge-www.ebaymotors.com-$100
Gauge Pod-www.ebaymotors.com-$25
Joe P MBC-www.boostcontroller.com-$35
Old Feb 15, 2004 | 12:24 AM
ilivas's Avatar
That should be good for low 12's or high 11's @ 25psi boost.
Old Feb 15, 2004 | 12:36 AM
ilivas's Avatar
No, I only have about 3/4 of the stuff on that list. Should have everything on the list in the within a month tho.
Old Feb 15, 2004 | 12:39 AM
ilivas's Avatar
I forgot to mention, you have to have a cat-back exhaust. turbo xs, greddy, hks, bosal. It's all good, just make sure it's 3 in at least. You MUST HAVE 3IN EXHAUST for that turbine or you will lose quite a bit of power. You can get away with 2.5 in on the stock turbo or IHI vf turbo's but not the 18g.
BTW the FP 18g turbo is not on their site, you have to call them and ask for it. If you really have money to blow, buy the 20g turbine instead which is around $1100.
Old Feb 15, 2004 | 07:37 AM
meilers's Avatar
Just out of curiosity -- why would you need both a UTEC and a manual boost controller? Once you have tapped your ECU, the boost controller seems redundant...
Still, that's a hot setup -- many people forget about upgrading the fuel system. Many people also forget about race-tuning their cams as well (which is fairly cheap) -- but that makes the car less streetable...
Old Feb 15, 2004 | 08:04 AM
SUB-ZERO's Avatar
I have a TXS STG 4+ (with TMIC) and I run 12.3-12.7 all day. I've never had any tranny problems but I am carefull upon launches. I also use a VF-30 and a ver2 UTEC for my engine management.
Old Feb 15, 2004 | 01:16 PM
For the same money over a new WRX, you could have had an STi and that is that.
Old Feb 15, 2004 | 01:25 PM
SUB-ZERO's Avatar
An STI will never even come close to a WRX with a STG4+. If you launch properly in a STG4 you can run 11.9's. The best an STI can run is about 13.2 which I've personally never seen. The best run I've seen an STI do at the track was a 13.3 and there was about 6 STI's racing. A stock WRX is about $24k, the STG4 is about 4k more.
STI's are pretty sweet though, If the STI would of been out at the begining of 2003 I would gotten one instead of the WRX. Now that my WRX is modified, I'll never trade it for an STI. I actually test drove one when I was thinking of trading in my WRX but decided it wasn't worth it.
-SZ
