Negative/Positive Effects???
Old Oct 28, 2004 | 01:21 PM
GDB-EJ20's Avatar
Car Info: Its a gross polluter : (
I have those items, and i think i run rich because my car back fires. I was told by Vishnu Performance that i will have these problems until i buy a piggyback ecu or reflash mine.
Old Oct 28, 2004 | 07:31 PM
playa7's Avatar
Car Info: JBP 04' WRX
your CAI will make you run a little lean. and your bov will make you run a little rich(only between shifts or when you let off the throttle).
Old Oct 28, 2004 | 07:43 PM
Lurk's Avatar
All those mods should lean it out a little bit. Except for the H-RFL blow off valve. Ditch that thing, its a POS.
Old Oct 28, 2004 | 07:51 PM
playa7's Avatar
whats wrong with that BOV? its hella fun scaring ppl with the loud azz PSSSHHHTTT! followed by back fire that sounds like gun shots....lol
question: how does an up/down pipe w/cat back make the car run lean?
not trying to be an azz just being curious is all.
Old Oct 28, 2004 | 08:05 PM
MO REX's Avatar
Car Info: 02 PSM WRX
The bov and cai will cost you around $450 and if you do a search you will find that they will do nothing for your cars performance and they can actually cause problems. I think the TXS RFL bov vents 100% atmospheric (not sure though) which isnt the best for a factory turbo application. If you really want that sound you may want to look into the GFB bov (or something like it) since it is adjustable and can run 50/50 (50%atmospheric vent/ 50% recirculation). I'm not saying that these parts are useless with all applications but they are with only an upipe and DP.
If I were you I would use that $ for some engine management unless you just want the bov for the niose.
Old Oct 28, 2004 | 10:56 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
agree
the cai intake makes the car run lean because they car cannot accurately measure the amount of air flow going into the motor. a stock air box is best unless you get your car dyno tuned.
Old Nov 4, 2004 | 05:19 AM
ilivas's Avatar
cai does make the car run LEANER but that doesn't mean it's running lean. It runs pretty rich from the factory, and the stock ecu can probably compensate for that minor mod.
The gfb bov is a POS. It wouldn't hold 22 psi at all.
Old Nov 4, 2004 | 06:51 PM
MO REX's Avatar
Are you running 22 pounds of boost and if so what setup are you running?
Old Nov 5, 2004 | 01:03 AM
ilivas's Avatar
Full TBE
uppipe
UTEC
BLitz SUS intake
Turbo XS FMIC
HKS BOV
Ultimate Racing 600 cc injectors
Walbro Fuel pump
Helix Oil catch can
Grounding kit
USDM STi 6 speed transmission
R180 rear diff
Turbo XS High performance boost controller
Forced Performance td05-18g turbo with ported turbine housing.
22 psi on pump gas and 26 psi on 100 octane.
Old Nov 5, 2004 | 02:59 PM
MO REX's Avatar
Full TBE
uppipe
UTEC
BLitz SUS intake
Turbo XS FMIC
HKS BOV
Walbro Fuel pump
Helix Oil catch can
Grounding kit
R180 rear diff
I'm jealous. That thing must be a beast.
Old Nov 5, 2004 | 03:16 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
That makes it even right? J/K
Old Nov 6, 2004 | 12:52 AM
ilivas's Avatar
lol
Old Nov 6, 2004 | 12:53 AM
ilivas's Avatar
it's still not fast enough yet.
Old Nov 6, 2004 | 03:54 PM
playa7's Avatar
i guess so ......thats what my friend told me. haha
SR-EURO
Dec 8, 2006 03:59 PM
JTech
Feb 12, 2005 10:54 PM
zoke
Jun 8, 2004 08:16 PM
Danno
May 2, 2003 09:32 AM
portollawrx
Apr 28, 2003 02:05 AM
