Need Knowledge
Old Oct 14, 2009 | 04:46 PM
csubaru04's Avatar
Car Info: 04 WRX
Need Knowledge
I have a 04 wrx .25 over on cylinders, vf34, perrin/ic ,sti pinks, exhaust,cobb access port, had engine rebuilt prob. 15k ago. loss of engine power and turbo not spooling over 8psi except sometimes when cold, exst temp runs hotter than normal it seems just regular driving almost 14. thimking maybe a bad hose but why only sometimes will it spool and why no power from the engine? Not showing any codes. Please any advice is better than none..
Old May 25, 2010 | 09:11 PM
fabwiz's Avatar
Car Info: 07' STi
Are you running a pill in the waste gate line?? Check everything around the waste gate area and its parts make sure you are not dumping boost
Old May 27, 2010 | 03:32 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Sounds like your ECU has pulled out a lot of timing and then dropped boost. This generally happens when knock occurs or if the ECU is picking up noise that it interprets as knock. Have you talked to your engine builder and/or tuner?
-- Ed
RC000E
Nov 27, 2005 02:49 AM
j0kr187
Dec 23, 2004 10:22 AM
j0kr187
Dec 19, 2004 04:53 PM
4080wrx
Sep 30, 2003 01:05 PM
ImprezaRulz
Jun 7, 2003 02:23 PM
Top
