need help?!!! overboosting!
Old Feb 15, 2005 | 03:11 PM
fliped wrx's Avatar
Angry need help?!!! overboosting!
just wondering..why in the hell am i overboosting..when i go through the gears 1-2 its fine..but when i hit third and above am boosting .12 for some dumb a$$ reason..and goes back down to .01 again..wth?? i installed a apexi gt spec exhaust and a helix down pipe and cut the resevoir from the intake (the silencer bottom of it)...can someone help me out here?..is it because of my exhaust connection maybe loose or what? thanks guys..
Old Feb 15, 2005 | 05:17 PM
duo's Avatar
duo
Car Info: WRB WRX 2004
you do get a higher boost level when you put on a tbe. What your explaning is a boost spike. Also i think you might want to get tuned soon. It will most likely keep your boost in check and help you get the most power out of your car.check your pms by the by
Joel
taerron
Feb 8, 2005 05:31 PM
NeRdY DoRkUs
16
Dec 23, 2004 10:26 PM
kdogpenny1
Apr 30, 2004 11:16 PM
dashiet
13
Dec 25, 2003 02:18 PM
turborambler
Oct 14, 2003 01:49 PM
