Need Help Check Engine Light On
Old Sep 14, 2007 | 08:25 PM
slowwrx02's Avatar
Car Info: bugeye cobb stage 2
I Have A 2002 Wrx Mods: Cobb Stage 2, Headers/up Pipe/downpipe/exhaust/ K&n Drop In Filter. Now Is Just Installed Act Hd/ Light Flywheel Now My Check Engine Light Is On. Whats The Damn Problem Please Help Me!!!!!!!!!!!!!!!!!!!!!
Old Sep 15, 2007 | 02:53 AM
03_Impreza_Al's Avatar
probably misfiring.
Old Sep 15, 2007 | 05:07 AM
taerron's Avatar
get the code pulled and then you can find out whats wrong....
Old Sep 15, 2007 | 09:33 AM
slowwrx02's Avatar
codes are P0301-cylinder 1 misfire P0304- cylinder 4 misfire
and P0300 it's not on my acessport diagnostic trouble codes. does anyone what it is. is the lightweight flywheel cause the misfire?
Old Sep 15, 2007 | 09:35 AM
yezzir.
Old Sep 15, 2007 | 09:41 AM
slowwrx02's Avatar
sooo.. there's no way i could fix it with takin out the flywheel??
Old Sep 15, 2007 | 09:48 AM
^ Well I heard having too light of a flywheel will throw the misfires.
You can try contacting a local tuner and see if they can get you a protune. Maybe they can get your timing in line.
Hows the health of your motor?. The misfires started after the lightened flywheel right? My friend has this same code.
Old Sep 15, 2007 | 09:52 AM
slowwrx02's Avatar
the motor is fine is just happen when i installed ACT flywheel 13.9 lbs.
Old Sep 15, 2007 | 09:54 AM
slowwrx02's Avatar
hey man i have a ACT lightflywheel for sale on has 50 miles on it interested??
Old Sep 15, 2007 | 09:56 AM
^ Yah just call your local suby tuner.
http://dbtuned.com/contact.html
Located in Roseville good luck! I'm pretty sure they can check it out for you diagnostics and all that good stuff or find a Access port Tuner.
Call around and see what you want to do.
haha my car is to slow for a light flywheel.
Old Sep 15, 2007 | 10:00 AM
slowwrx02's Avatar
ur friend with the same problem as me does he have a light fly. if he fix the problem how??
Old Sep 15, 2007 | 10:14 AM
^ he hasn't fixed the problem he gets a misfire at a certain temp. He's untuned but i'm pretty sure you can get a protune to get that cleaned up. To help line up the timing.
Old Sep 15, 2007 | 10:21 AM
slowwrx02's Avatar
thanks for ur help hopefully i can get the car running right w/out removing the fly. if not have to sell the damn thing.
TSNWrX07
Aug 10, 2008 09:01 AM
06scooby
Oct 15, 2006 10:11 AM
BRIAN J.
Mar 20, 2006 07:04 AM
banpreso
Jun 13, 2003 09:31 AM
