need help with bov
Old Feb 25, 2003 | 06:42 PM
WickedRydaX's Avatar
Car Info: Black WRX, X.S. turbo back exhaust, X.S. cold air, and a lot of plans
What other mods do you have? Also try taking the bov off, and putting the stock bypass on, and if it still makes the sound go to the dealer.
Old Feb 27, 2003 | 12:58 AM
turborambler's Avatar
BOV noise
When I got my GFB valve put on (100 atmospher...gonna change it to 50/50) I was kind of shocked at the noise myself. I my car is an automatic and when I release the throttle at low or no boost it makes kind of a sputtering sound. Anyone else here this noise? It sounds like a piston toggling for a few seconds. Under full boost it makes the psst. Is this normal? Now you have me worried about it! The noise seems less loud now, maybe because I got used to it...hopefully its that.
Ken
Old Feb 27, 2003 | 09:39 AM
If you have cats still you want to have it on 50/50 because you are shooting out metered air with teh BOV. Which means there is fuel for that air, but no air so the cats have to work hella hard to burn that gas off. I'm only running the uppine cat ( no for much longer), so I'm running it 100% off.
Old Feb 28, 2003 | 12:21 AM
Thats good, least something isn't broken. I'm changing mine to 50-50 as well and eventually I might get rid of the whole thing.
Old Mar 13, 2003 | 01:28 PM
My valve by GFB made that sound especially when it was 100% atmosphere. As time went on the sound did diminish. It still makes that sound at low RPMs though. I was quite surprised at that sound when it was first installed!
unstble
Mar 21, 2008 09:09 AM
ViVaSuBy
Sep 26, 2007 03:30 PM
subiedave
15
Oct 20, 2005 07:56 AM
