Need help with Blitz FMIC
Old Aug 6, 2003 | 01:39 PM
international B's Avatar
Chewwwwy
i would say that the turbo is running out of breath. with a huge fmic, the turbo has to pressurize alot of air to build up boost. one problem is your stock up/down pipes. in order to free up the turbo, you will need to replace atleast the up pipe with a catlesss one. i would go that route first since it is the cheapest, and will add the most performance. how long have your spark plugs been in?? i missfire cel is usually caused by fouled plugs, the colder intake charge will allow the ecu to run more timing, thus running lean. but since you are running stock boost, i dont see that lean would be a problem.
i would reccomend running 1 step colder plugs, and changing the up-pipe.
good luck
aaron
Old Aug 6, 2003 | 02:09 PM
AFIwrx's Avatar
well an uppipe and plugs will help but its not going to solve everything. your ecu is seening the f/m and it doesnt know whats going on your going to need some type of engine management and a well tuned map to make everything run smother. It sounds like your running way too lean you need to change the injectors and you need a fuel pump. what made you buy the f/m your not going to see any improvement over stock with just a f/m you need a upgraded turbo and all the supporting mods then youll feel the differnce
well good luck
mike
XkrazyAsianX
16
Mar 22, 2005 03:13 PM
STI808
Hawaii Classifieds
28
Sep 20, 2004 10:12 PM
sheff
Jul 20, 2004 09:50 AM
STiNightFall
Jan 16, 2004 04:16 PM
ITF001
Feb 27, 2003 10:02 PM
