is more liters better?
Old Apr 16, 2004 | 01:47 PM
nic3krnnamja83's Avatar
is more litter neccarily better, cause i notice race cars always seem to have the least liter possible?
Old Apr 16, 2004 | 02:02 PM
RussB's Avatar
Car Info: $200,000 sports car
huh?
Old Apr 16, 2004 | 02:04 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
more liters = more displacement = potential for more HP/torque
ever hear that saying: "there is no replacement for displacement"
small displacement engines are not as readily capable of "high HP/torque" applications as bigger engines are, w/more displacement.
however, smaller engines with less displacement are capable of running at much higher RPMs than bigger engines are. So it really depends on your application.
hope this helps.
-Ted
Old Apr 16, 2004 | 02:16 PM
perfect gotboost thanks
but is being capable of running higher rpm's on smaller disp. cars necessarily better? because i am debating whether or not to trade in my rex for sti and i ma looking for every possiblity. I know Imprezers car runs at 9500 rpms i think on 2.4
Old Apr 16, 2004 | 04:04 PM
DizzyWRX's Avatar
Another thing about why racecars have a smaller displacement is because their racing circuit limits the size to try to keep it even between each car. I believe that WRC limits their competitors 2 liter engines.
Old Apr 16, 2004 | 04:55 PM
oic, but they produce so much power out of them
Old Apr 16, 2004 | 05:08 PM
Wrxneffect's Avatar
Car Info: 03 Wrx black sedan + 2013 BRZ
Yeah but they have bigger budgets than most ppl so their cars don't have to last all that long:banana:
Jason
Old Apr 16, 2004 | 05:09 PM
aww the light has shined (ding)
thanks guys
Old Apr 16, 2004 | 06:52 PM
Choku Dori's Avatar
Car Info: Corvette Z51
If you used to be into domestics, think of liters as a different measure of cubic inches.
Also, WRC cars are only limited to 2 liters with forced induction. I believe the limit for non-forced induction is 3.5 liters. Also, WRC cars make about 300 - 350 hp or so; it's their anti-lag systems that make them so insanely fast (well, among other multi-million dollar bits of technology). Also, like WRXnffect said, longevity is of no issue to WRC teams.
Just for reference, some F-1 cars run 3 liter V12's! On the flipside, the Dodge Viper has an approximately 8 liter V-10
Old Apr 16, 2004 | 06:58 PM
thanks for the break down choku
Old Apr 16, 2004 | 07:36 PM
GotBoost?'s Avatar
thats also the reason why you will rarely find a 4-banger in a hardcore rock crawler....because a 5.0-5.7 liter (302-350ci) v-8 will produce much more torque at 2500-3000 RPM than a 2 or 3 liter 4cyl. Granted you can make up for a certain amount of lost torque with your gearing, but put that same gearing with a v-8 and you will climb trees in a jeep!
like a stomper...."you can try and stop 'em, but you cant"
-Ted
Old Apr 16, 2004 | 08:02 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
You guys are so nice here...this guy would've gotten torn up at Nabisco!
<warm and fuzzy feeling>
Old Apr 16, 2004 | 08:25 PM
i would have? i dont like nasioc all that much, except u guys, cause i know some of you post there
Old Apr 16, 2004 | 10:00 PM
snicklous's Avatar
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
like GOTBOOST said. the more cdi you have the more low end torque you will have because the crank is bigger. with the added length and weight of the crank the motor wants to keep rotating. the same as if you put a really light weight flywheel on your car you launch rmp would suffer but if you kept the stock crank your take off r's would be much lower
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
dw
Jan 2, 2006 03:47 PM
gpatmac
May 29, 2005 08:23 PM
