more boost?
Old Aug 8, 2009 | 01:59 AM
kingk's Avatar
Car Info: 2002 impreza wrx
more boost?
Can i get more boost out of the stock turbo, without buying anything? Had a friend that made a bigger hole in a diaphram (think it was for the wastegate) and got more boost. Is it posible?
Old Sep 2, 2009 | 01:42 PM
wrx-auto-x's Avatar
Car Info: WRB Stage 2 Bugeye
they only way to saefly get more boost is a tune, our cars ecu's control the boost. TBE, intake, gutted or catless UP, then open source stage 2 map or cobb AP will up your boost and keep smiles on ur face. or just take ur car to a tuner, but do NOT get a manual boost controller for more boost our cars are not engineered for those. so you want more boost, buy parts or go get tuned.
Old Sep 2, 2009 | 02:14 PM
johndabrit's Avatar
Da Brit.
I mostly agree with this but I'm running a manual boost controller along with thousands of others. Point is there is nothing wrong with a MBC as long as you are tuned for it. If you are getting a MBC just to turn the boost up without the tune then yes I agree 100 percent do NOT get one.
Old Sep 4, 2009 | 08:19 PM
WRXXX's Avatar
Car Info: 2003 sonic yellow WRX, Vishnu Stage 1, Perin Inter
I have a question for Johndabrit, just for curiosity sake....why would you install a MBC then have the car tuned to run with the boost controller? Why wouldn't you have the factory ECU tuned to increase the boost pressure? That way you would still keep the factory ECU safety features? Seems to me the MBC in unnecessary. Is there an advantage to this?
Old Sep 4, 2009 | 09:31 PM
johndabrit's Avatar
Da Brit.
the perks are:
improved consistency with rock solid peak boost numbers
faster spool times. (getting an up-pipe will help this also)
provide a boost level which simply will not be exceeded to prevent spikes and overboost. (overcharging)
It's more about efficiency over capability. The downside in a MBC setup is that should something go wrong with your setup, your ECU has no way of controlling your boost. It might be trying to cut boost, but since it has no control, it can't and you can end up blowing things up. There is also a theory that for example, 18psi on mbc is 18lbs no matter where the throttle is and can lead to motor issues as peak boost on partial throttle can be bad. I don't have enough experience on this to make a verdict. Your thoughts?
Old Aug 3, 2010 | 11:56 PM
kingk's Avatar
Thanks guys for the reply's. Anyone else have any comments on this.
Aloha
Old Aug 4, 2010 | 12:16 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
the perks are:
This is mostly right.
The MBC's main advantage is response and consistency. Part throttle boost conditions are 100% safe as long as the tune is set up to handle it. The idea that it is dangerous comes from 2003 before the open loop/closed loop switchover maps were discovered in the ECU.
-- Ed
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
To the OP, you need to get the car tuned to safely raise boost levels. Do not just try to trick the ECU or mechanically raise boost as the stock tune is not set up for this and will cause damage to the engine over time.
-- Ed
Old Aug 4, 2010 | 12:20 PM
johndabrit's Avatar
Da Brit.
-- Ed
that post i made seems like forever ago although it was just a year ago. By re-reading it and comparing it to the knowledge i have now its really obvious I've learned so much since then haha. It's a trip what you can learn about these cars in a year.
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
yzercyber
Aug 12, 2005 03:42 PM
Kostamojen
May 18, 2003 11:46 PM
MPOWERD
Mar 19, 2003 08:23 PM
